メインコンテンツにスキップ
HP Pavilion 15-ba003ds Disc Drive Removal
Kristen Gismondi
Kristen Gismondi とその他 2 人の作成者
最終更新日: March 7, 2025
5 - 10 分
とても簡単
作成中の学生
より良い紹介部分
詳細が不足
If your HP Pavilion 15-ba003ds disc drive is making unusual clicking sounds or failing to read discs properly, you may be dealing with a faulty drive. This could be caused by a dirty lens covered in dust, preventing the drive from reading the disc and causing it to repeatedly search for it.
If cleaning the lens doesn't fix the issue, this guide will provide you with step-by-step instructions on safely accessing and removing the Disc Drive.
Before beginning the repair, make sure to find your laptop's model name, product number, and serial number. You can locate these on a sticker at the bottom of your device or behind the battery on some models. The model name will look like "Pavilion 15-bxxxxxx," while the product number will consist of letters and numbers, such as "D8X43UA." These details are important for finding the right drivers and getting support.
Whether you're replacing a faulty drive or upgrading to a new one, these instructions will help you complete the process.
Be sure to power down your device before starting to prevent any potential damage or safety hazards.
必要な工具と部品
ツール
  1. HP Pavilion 15-ba003ds Disc Drive Removal, Battery: 手順 1、 2の画像 1 HP Pavilion 15-ba003ds Disc Drive Removal, Battery: 手順 1、 2の画像 2
    • Unplug the AC adapter from the corresponding socket in the laptop.
    • Turn off your laptop before starting this procedure. Make sure it's not in sleep or hibernation mode.
    • Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
    • Carefully slide the battery out of the laptop frame and place it somewhere safe.
  2. HP Pavilion 15-ba003ds Disc Drive Removal, Disc Drive: 手順 2、 1の画像 1
    • Remove the two rubber feet next to the battery.
  3. HP Pavilion 15-ba003ds Disc Drive Removal: 手順 3、 2の画像 1 HP Pavilion 15-ba003ds Disc Drive Removal: 手順 3、 2の画像 2
    • There are twelve 8mm screws in total that need to be unscrewed
    • Using a Phillips #00 screwdriver, unscrew them all including the two screws found underneath the rubber feet.
  4. HP Pavilion 15-ba003ds Disc Drive Removal: 手順 4、 2の画像 1 HP Pavilion 15-ba003ds Disc Drive Removal: 手順 4、 2の画像 2
    • Once all twelve screws are removed the disc drive can now be gently pulled out by hand.
終わりに
作成者
2人の作成者と共同で作成されました。
Kristen Gismondi
メンバー登録日: 11/12/14
92,639 ポイント
241のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,648のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 21
今までの合計 176
