メインコンテンツにスキップ
HP Envy 4-1105dx  Hard Drive Replacement
KC Armstrong
KC Armstrong とその他 人の作成者
最終更新日: January 4, 2018
25分
中レベル
Use this guide to replace your hard drive. If you have determined that your hard drive is not working or if you want a hard drive with more storage space, it may be time to replace it.
必要な工具と部品
ツール
  • Phillips #1 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
もっと見る
  1. HP Envy 4-1105dx  Hard Drive Replacement, Battery: 手順 1、 1の画像 1
    • Power off the device before beginning disassembly. Disconnect all external devices.
    • Flip the device on its back.
  2. HP Envy 4-1105dx  Hard Drive Replacement: 手順 2、 1の画像 1
    • Unscrew and remove the one 7.5 mm Phillips-head screw using Phillips #1 screwdriver.
  3. HP Envy 4-1105dx  Hard Drive Replacement: 手順 3、 1の画像 1
    • Unscrew twelve 6.0 mm Phillips-head screws using Phillips #1 screwdriver.
  4. HP Envy 4-1105dx  Hard Drive Replacement: 手順 4、 1の画像 1
    • Use the plastic opening tool (which is short and has a thin end for prying open device parts) to pry open the back case of the device.
  5. HP Envy 4-1105dx  Hard Drive Replacement: 手順 5、 1の画像 1
    • Once the device is open, move the ribbon cable to the side.
  6. HP Envy 4-1105dx  Hard Drive Replacement: 手順 6、 1の画像 1
    • Use the flat end of a plastic spudger to disconnect the battery cable from its socket in the motherboard.
  7. HP Envy 4-1105dx  Hard Drive Replacement: 手順 7、 1の画像 1
    • Unscrew and remove the three 4.0 mm Phillips-head screws that hold the battery in place, using a Phillips #1 screwdriver.
  8. HP Envy 4-1105dx  Hard Drive Replacement: 手順 8、 1の画像 1
    • Lift the battery up and remove.
    • Removing the battery can dislodge the touchpad bracket. Place the battery carefully over the alignment pins.
  9. HP Envy 4-1105dx  Hard Drive Replacement, Hard Drive: 手順 9、 2の画像 1 HP Envy 4-1105dx  Hard Drive Replacement, Hard Drive: 手順 9、 2の画像 2
    • Remove the four 4.0 mm screws that hold down the hard drive case using a Philips #1 Screwdriver.
    • Move the hard drive case and hard drive so that you can easily reach the hard drive cable.
  10. HP Envy 4-1105dx  Hard Drive Replacement: 手順 10、 3の画像 1 HP Envy 4-1105dx  Hard Drive Replacement: 手順 10、 3の画像 2 HP Envy 4-1105dx  Hard Drive Replacement: 手順 10、 3の画像 3
    • Use the plastic spudger tool to loosen the hard drive SATA cable connection by pushing it away from the motherboard.
    • Once it is loose, pull the hard drive out of the socket.
    • Remove the hard drive from the device.
  11. HP Envy 4-1105dx  Hard Drive Replacement: 手順 11、 3の画像 1 HP Envy 4-1105dx  Hard Drive Replacement: 手順 11、 3の画像 2 HP Envy 4-1105dx  Hard Drive Replacement: 手順 11、 3の画像 3
    • Pull out the hard drive cable from the hard drive, and set it aside.
    • Remove the four 3.0 mm screws that attach the hard drive case to the hard drive using a Philips #1 Screwdriver. If the screwdriver is too big, try #0 sized screwdriver.
  12. HP Envy 4-1105dx  Hard Drive Replacement: 手順 12、 1の画像 1
    • Remove the hard drive from the hard drive case.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
KC Armstrong
メンバー登録日: 10/03/17
177 ポイント
2のガイドは作成済み
チーム
Portland State University, Team S1-G1, Romaine Spring 2018 Portland State University, Team S1-G1, Romaine Spring 2018人のメンバー
PSUN-ROMAINE-S18S1G1
7 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 916
