メインコンテンツにスキップ
HP Elitebook 8460p Hard Drive Replacement
Garrett Anderson
Garrett Anderson とその他 2 人の作成者
最終更新日: March 22, 2022
20分
簡単
Use this guide if the hard drive in the HP Elitebook 8460p failed or you are looking to upgrade your hard drive with either a new spinning hard drive or a solid state hard drive. The hard drive is where all the data on your laptop is stored - including the Operating System. Before you remove the hard drive, it is strongly recommended to create a backup of all your data.
Most replacement hard drives should come with further instructions or a software tool to back up all the data on your current hard drive and transfer it to the new hard drive before installing the new hard drive.
Before opening the laptop up to replace the hard drive, ground yourself with an ESD strap to prevent electrostatic discharges from damaging or ruining other sensitive electrical components in the laptop.
To complete this guide, you will need a Phillips screw driver #0, an ESD grounding strap, and a replacement SATA hard drive in a 2.5 form factor.
必要な工具と部品
修理キット
キットには、修理ガイドを完了するために必要な全ての部品とツールが含まれています。
パーツ
ツール
もっと見る
  1. HP Elitebook 8460p Hard Drive Replacement, Battery: 手順 1、 1の画像 1
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
    what if it does not work,what does that mean?
    julia melrose - 返信
  2. HP Elitebook 8460p Hard Drive Replacement: 手順 2、 1の画像 1
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Hard Drive Replacement, Back Panel: 手順 3、 1の画像 1
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Hard Drive Replacement: 手順 4、 1の画像 1
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Hard Drive Replacement, Hard Drive: 手順 5、 2の画像 1 HP Elitebook 8460p Hard Drive Replacement, Hard Drive: 手順 5、 2の画像 2
    • Attach an ESD strap to your wrist and to a ground.
    • Pull the tab with the small engraved arrow up and towards the inside of the laptop.
  6. HP Elitebook 8460p Hard Drive Replacement: 手順 6、 2の画像 1 HP Elitebook 8460p Hard Drive Replacement: 手順 6、 2の画像 2
    • Using a Phillips #0 bit, unscrew the three screws that hold the hard drive assembly in place.
  7. HP Elitebook 8460p Hard Drive Replacement: 手順 7、 2の画像 1 HP Elitebook 8460p Hard Drive Replacement: 手順 7、 2の画像 2
    • Remove the silver metal cover by pulling straight up on the black tab.
  8. HP Elitebook 8460p Hard Drive Replacement: 手順 8、 1の画像 1
    • Disconnect the hard drive by pulling the drive straight out to the left.
    • If replacing the hard drive, seat the new hard drive firmly in the connector.
終わりに
10 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Garrett Anderson
メンバー登録日: 09/16/19
2,250 ポイント
10のガイドは作成済み
チーム
4 件のコメント
Thanks! This made hard drive replacement on Elitebook VERY Easy!
Patrick Murphy - 返信
Awesome! So glad that it was able to help you out and keep your Elitebook running. Have a wonderful day!
Garrett Anderson -
Now it won't see the new HD to install to. W10 says the drive can't be used for booting and to enable it in BIOS.
Can't find where to enable it, however.
Rich Frueh - 返信
Meh. Took out battery, let sit for a while. Hit power a few times, plugged back in, and presto!
Not my favorite HP laptop.
Rich Frueh -
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 91
今までの合計 6,833
