メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP EliteBook 840 G3 Keyboard Replacement
Richard Brooks
Richard Brooks とその他 2 人の作成者
最終更新日: 2024年9月23日
見積もりなし
中レベル
コミュニティメンバーによる寄稿ガイド
  1. HP EliteBook 840 G3 Keyboard Replacement, Safely remove the keyboard: 手順 1、 1の画像 1
    • HP's service manual for this computer is a great document. But on page 52, it says to "insert a thin tool into the hole beside the fan assembly". But their illustration doesn't actually show the location of that hole. Worse yet, molded into the plastic, there is a keyboard symbol and an arrow POINTING THE WRONG WAY (zoom into my picture, you'll see what I mean).
    • To save you trouble, I've outlined the hole in RED in the photo I have attached. You can remove the keyboard by using the back end of your spudger, a small wooden dowel or similar non-conductive tool, and applying slight pressure until the keyboard lifts up enough for you to get your pick, or fingernails under it.
    • The rest is easy. Just be careful not to pull the keyboard away until you carefully disconnect the keyboard cable (and possibly an additional power cable if your keyboard is backlit).
ゴール
4 の人々がこのガイドを完成させました。
Gear Up For Future Repairs
Shop all
作成者
2人の作成者と共同で作成されました。
Richard Brooks
メンバー登録日: 08/08/19
445 ポイント
2のガイドは作成済み
3件のガイドコメント
this is not a elitebook 840 g3 inside. There is a bracket where you have to remove 2 screws to remove the keyboard
ncata - 返信
For a person who commented above: you are wrong, this is how elitebook 840 g3 looks like. After removing 2 screws I got stuck at the same issue with the arrow as the author explains. THANK YOU FOR THIS GUIDE IT SAVED ME A LOT OF TIME !
Albert Einstein - 返信
Update - HP's service manual for their computers has disappeared, but they have a lot more of their own service videos on their YouTube channel. In this particular case, they demonstrate in this video using a wooden dowel how to pop they keyboard loose like their manual describes. The audio is actually just the computer reading the steps from their manual. If any one can find the manual, please add it here.
Richard Brooks - 返信
コメントを追加
統計データ:
過去 24時間: 10
過去 7 日: 53
過去 30 日: 207
今までの合計 5,558
