メインコンテンツにスキップ
HP 225 G7 Battery Replacement
Stratos Thivaios
Stratos Thivaios とその他 人の作成者
最終更新日: March 27, 2024
15 - 30 分
簡単
コミュニティメンバーによる寄稿ガイド
This guide will help you replace the battery of your HP 255 G7 laptop.
必要な工具と部品
ツール
もっと見る
  1. HP 225 G7 Battery Replacement, Flip The Laptop Upside Down: 手順 1、 1の画像 1
    • Firstly, flip the laptop upside down, so that you are looking at the bottom of it, and the hinge of the screen is facing away from you.
  2. HP 225 G7 Battery Replacement, Remove The Rubber "Leg": 手順 2、 2の画像 1 HP 225 G7 Battery Replacement, Remove The Rubber "Leg": 手順 2、 2の画像 2
    • Use the spatula to remove the rubber "leg", all the way until it is completely removed.
  3. HP 225 G7 Battery Replacement, Remove The Upper Rubber "Leg": 手順 3、 1の画像 1
    • Repeat for the top rubber.
  4. HP 225 G7 Battery Replacement, Unscrew: 手順 4、 3の画像 1 HP 225 G7 Battery Replacement, Unscrew: 手順 4、 3の画像 2 HP 225 G7 Battery Replacement, Unscrew: 手順 4、 3の画像 3
    • Unscrew all the screws from the laptop, including the ones that were under the rubber "legs".
    • There should be 11 screws in total. (4 under the upper leg, 3 under the lower one, and 4 that were not under rubber).
  5. HP 225 G7 Battery Replacement, Start Inserting The Picks: 手順 5、 1の画像 1
    • Carefully insert a pick under the touchpad of the laptop.
  6. HP 225 G7 Battery Replacement, Continue Inserting Picks: 手順 6、 1の画像 1
    • Continue inserting picks all the way around the laptop.
  7. HP 225 G7 Battery Replacement: 手順 7、 1の画像 1
    • Pull apart the cover and the body of the laptop.
    • If you find resistance, reduce the angle of the screen hinge, since the hinge might be "clamping" the cover.
    • If you still find resistance, check for any forgotten screws on the bottom. Never apply too much pressure if there is a lot of resistance.
  8. HP 225 G7 Battery Replacement: 手順 8、 1の画像 1
    • Finally, the bottom of the laptop should look like that.
  9. HP 225 G7 Battery Replacement, Locate and unscrew the 3 screws holding the battery: 手順 9、 1の画像 1
    • Locate and unscrew the 3x Philips 1 screws that hold the battery.
  10. HP 225 G7 Battery Replacement, Remove the battery: 手順 10、 3の画像 1 HP 225 G7 Battery Replacement, Remove the battery: 手順 10、 3の画像 2 HP 225 G7 Battery Replacement, Remove the battery: 手順 10、 3の画像 3
    • After unscrewing the 3 screws, pull the top side of the battery up then slide it out to remove it.
    • Fire Hazard : Always handle lithium batteries with caution.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Stratos Thivaios
メンバー登録日: 02/27/23
1,305 ポイント
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 6
過去 30 日: 23
今までの合計 288
