はじめに
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to remove or replace the charging assembly on your Google Pixel 4. The charging assembly contains the USB-C port, as well as some antenna connectors, and is layered underneath the loudspeaker and battery.
This process requires removing the loudspeaker, which will compromise the loudspeaker’s ingress gasket.
Caution: Google warns that disassembly of the front laser assembly could result in hazardous exposure to invisible infrared laser emissions. Read their safety warnings here.
Warning: Do not reuse the battery if it has been deformed or damaged, as doing so is a potential safety hazard. Replace it with a new battery.
必要な工具と部品
Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the left edge of the phone.
Press firmly to eject the tray.
Remove the SIM card tray.
Prepare an iOpener and apply it to the bottom edge of the back panel for one minute.
Apply a suction cup to the heated edge of the back panel by pressing down on it to create suction, as close to the edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame.
Insert the point of an opening pick into the gap.
Slide the opening pick across the bottom towards the left corner to slice the adhesive.
With the pick still inserted, slide it from the bottom left corner over to the bottom right corner to completely slice the bottom side adhesive.
Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
Prepare an iOpener and apply it on the left edge of the phone for one minute.
Prepare an iOpener and apply it on the right edge of the phone for one minute.
Slide the third opening pick around the top right corner and across the top side of the phone, slicing the final strip of adhesive.
Once you have sliced around the perimeter of the phone, carefully lift the right edge of the back cover, opening it like a book.
Do not try to pull the panel all the way off yet, as it is still connected to the phone.
この手順で使用する道具:Magnetic Project Mat$19.95
Remove the five T3 Torx screws securing the battery connector shield:
Four 4.0 mm screws
One 2.1 mm screw
Use a T3 Torx driver to remove the two 4 mm screws securing the back panel connector cover.
Pull on the yellow pull tab of the adhesive strip with steady force.
Continue firmly pulling up on the adhesive strip with constant force. If you're using a spudger, spin it every so often to keep the exposed section of the pull tab as short as possible.
Continue this process for each of the three pull tabs, until all are either out or have snapped in half.
If the battery tabs snapped during removal, insert an opening pick on the upper right edge of the battery, slicing the adhesive underneath.
この手順で使用する道具:Tesa 61395 Tape$5.99
Lift the battery up and away from the phone to remove it. You may need to peel the battery away from any leftover adhesive tabs.
If you're using stretch release adhesive, apply them onto the battery. Otherwise, apply some double-sided tape, or pre-cut adhesive strips in the phone's battery well, being careful not to cover the charge port flex cable. Peel away any tape liners to expose the adhesive.
Temporarily re-connect the battery's connector to the motherboard socket. This ensures that the battery is properly positioned.
Lay the battery in place and press firmly.
Disconnect the battery connector from its motherboard socket and resume re-assembly.
Remove the two T3 Torx screws securing the vibration motor cover:
One 4.2 mm screw
One 4.4 mm shouldered screw
Remove the two T3 Torx screws securing the loudspeaker:
One 4.2 mm screw
Use a pair of tweezers to slide the loudspeaker towards the top of the phone to clear the retention clip.
Remove the loudspeaker.
If it is in good condition, you can re-use the gasket. Make sure that the gasket does not cover the exit hole.
If the gasket is pulled out of place, remove it and replace the adhesive with a pre-cut strip or Tesa tape.
Use a pair of tweezers to disconnect the antenna press connector from the charging assembly by pulling it straight up from the motherboard.
Peel back the ribbon cable that's adhered to the phone's frame. It's secured with some light adhesive.
13 の人々がこのガイドを完成させました。
2 件のコメント
Be careful at step 5 to not force too much, as I broke a bit of my back panel, but I guess it's because it was already weakened by some falls.
In step 13, the back panel didn't come with the sticker, but did with the back panel connector which didn't stay connected to the inside of the phone.
One 4.0 mm screw was missing before I even used the T3 Torx.
It seems like my Pixel 4 was a refurbished one, as I didn't have the yellow adhesive strips of step 22.
For the reassembly, I highly recommand you to do step 31 and step 29 before the step 33 and do not forget to press down sides, as advised in step 16. Reconnecting the white antenna cable to the replacement charging assembly and to the inside of the phone was a bit tricky and I think I succeeded only thanks to luck.
Repairing the phone took me about nearly 3 hours, 40-50 minutes were used into the disassembly. It was my first reparation with an Ifixit guide.
Great guide. It was straight forward, and quite easy. Removing the adhesive was the most time consuming part, but thankfully the links to access the custom cut adhesive application tutorials made it easy.
The trickiest bit was removing the white antenna, since I wasn't sure how it was attached until I pulled out a magnifier! But even that was not difficult. I used tweezers to push open the tiny metal clips that hold it on the middle.
