メインコンテンツにスキップ
Fix for Vanmoof S2 Not Charging
Coleman Oei
Coleman Oei とその他 3 人の作成者
最終更新日: July 7, 2024
1時間
とても難しい
間違いの指摘
コミュニティメンバーによる寄稿ガイド
If your bike isn't charging, this guide might help you fix it.
必要な工具と部品
ツール
  1. Fix for Vanmoof S2 Not Charging, Bike not charging when plugged in: 手順 1、 1の画像 1
    • Under normal conditions, when plugged in and not fully charged, the light on the charger should turn red.
    • If it stays green (as shown) even while the bike itself indicates charging, the solution below will probably work for you.
    • Vanmoof has a great video on how to remove the smart cartridge. You will need to buy the necessary Torx wrench because I don't think it comes with the bike.
  2. Fix for Vanmoof S2 Not Charging, Open up the smart cartridge: 手順 3、 1の画像 1
    • Remove all the screws from the circled plate
    • Pull apart that half of the smart cartridge. There is adhesive near the charging port so it may be a bit tough to pull apart at that end.
  3. Fix for Vanmoof S2 Not Charging, Confirm the connector has arced: 手順 4、 1の画像 1
    • The pictured connector should look burnt in some way. It's possible that some end up completely melted.
    • Cut the plastic off the wires and then strip them so that they can be soldered to the pins
  4. Fix for Vanmoof S2 Not Charging, Solder the wires: 手順 5、 1の画像 1
    • Solder the wires to the pins where the connector used to go
    • Reassemble everything and the bike should now charge.
ゴール
18 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Coleman Oei
メンバー登録日: 07/08/22
823 ポイント
2のガイドは作成済み
32件のガイドコメント
Thank you. I'm not very skilled with such things, but it worked out pretty good and I didn't find it to complicated.
Marcel M - 返信
sure np I didn't think it was "difficult" either but the description of difficult said something like "requires soldering" so I put it as difficult 🤷‍♂️
Coleman Oei -
Fiddly but not complex. I was using a soldering iron for the first time and just about managed it. Thanks for the post.
Three Sea Shells - 返信
Hi, I have same problem, I think there is a problem with the bms ! Any idea how can I fix it ?
Kreont i - 返信
sorry. dont know much besides what I wrote above. If you have more details I might be able to help. There is also a vanmoof subreddit that has been able to instruct me on how to fix a lot of the issues ive had with the bike so you might try that.
Coleman Oei -
コメントを追加
統計データ:
過去 24時間: 16
過去 7 日: 103
過去 30 日: 650
今までの合計 17,758
