メインコンテンツにスキップ
DualShock 4 CHU-ZCT2U Charging Port Replacement
David Seale
David Seale とその他 7 人の作成者
最終更新日: May 7, 2024
25分
中レベル
より良い紹介部分
アーカイブされたガイド
このガイドは将来的な使用のためにのみ保存されてます。ご自身の修理作業には更新バージョンをご利用ください。
This guide will show you how to disassemble your DualShock 4 CHU-ZCT2U controller and access the charging port for replacement.
  1. DualShock 4 CHU-ZCT2U Charging Port Replacement, Outer Shell: 手順 1、 3の画像 1 DualShock 4 CHU-ZCT2U Charging Port Replacement, Outer Shell: 手順 1、 3の画像 2 DualShock 4 CHU-ZCT2U Charging Port Replacement, Outer Shell: 手順 1、 3の画像 3
    • Unscrew the four 6.5mm screws, using a Phillips-Head screwdriver.
    • Pry the two halves of the shell apart using a plastic opening tool.
    • Be careful, as there will be a ribbon connecting the inner workings of the controller. It will not separate into two parts just by pulling apart the shell.
    When re-asembling, be careful to check that all buttons/triggers are moving correctly. They can get misaligned when prying the two shell halves apart.
    Tale Spinner - 返信
    This part is missing vital information on how to correctly pry the case open. In the 3rd picture you can see there is actually damaged/broken clip already. In order to open the case without damage to the plastic clips inside the controller holding the plastics together you need to insert thin piece of metal between the trigger buttons on each side and push the clip outwards before trying to separate the parts, and if done correctly there is no force needed to pry open the controller. There is actually no necessary need for the clips, but if you want to keep your controller in mint condition without voiding the warranty, take care not to break these clips.
    Ville Närhi - 返信
    Your advice for opening shell was so bad and harmful.
    It's not correct
    Kiarash Moallemi - 返信
    And two more tiny clips to the left and right of the headphone & EXT port. They’re VERY delicate, reckless prying WILL break at least ONE of these.
    Strings Cat - 返信
    I've written a guide for how to find and unlatch the clips
    DualShock 4 CUH-ZCT2Uを開くための重要な作業
    Richard - 返信
  2. DualShock 4 CHU-ZCT2U Charging Port Replacement: 手順 2、 3の画像 1 DualShock 4 CHU-ZCT2U Charging Port Replacement: 手順 2、 3の画像 2 DualShock 4 CHU-ZCT2U Charging Port Replacement: 手順 2、 3の画像 3
    この手順で使用する道具:
    • Pull the ribbon cable out of the motherboard port to fully separate the two halves, using a pair of tweezers.
    If you just want to change the battery, this step is not necessary; it can be done without disconnecting the ribbon cable.
    Tale Spinner - 返信
  3. DualShock 4 CHU-ZCT2U Charging Port Replacement, Charging Port: 手順 3、 2の画像 1 DualShock 4 CHU-ZCT2U Charging Port Replacement, Charging Port: 手順 3、 2の画像 2
    この手順で使用する道具:
    • Pull the ribbon cable from the charge port, using a set of tweezers.
  4. DualShock 4 CHU-ZCT2U Charging Port Replacement: 手順 4、 3の画像 1 DualShock 4 CHU-ZCT2U Charging Port Replacement: 手順 4、 3の画像 2 DualShock 4 CHU-ZCT2U Charging Port Replacement: 手順 4、 3の画像 3
    • Grip the right hand corner of the opaque white piece with a pair of tweezers, and pull it upwards to remove it.
    Müssten heißen: “Fasse die rechte Ecke des WEISSEN Plastikteils …”
    Wolfgang Brandner - 返信
    You can buy for $20 a USB-C port board and replace mini b. It's connects to PS4 to register new remote and charge.
    DARKMATTER - 返信
  5. DualShock 4 CHU-ZCT2U Charging Port Replacement: 手順 5、 3の画像 1 DualShock 4 CHU-ZCT2U Charging Port Replacement: 手順 5、 3の画像 2 DualShock 4 CHU-ZCT2U Charging Port Replacement: 手順 5、 3の画像 3
    • Lift the clear plastic piece up by its right hand corner.
    • Pull it to the right to remove the bottom left hand corner from the groove.
    • Remove the clear plastic piece. It pushes in easily.
  6. DualShock 4 CHU-ZCT2U Charging Port Replacement: 手順 6、 3の画像 1 DualShock 4 CHU-ZCT2U Charging Port Replacement: 手順 6、 3の画像 2 DualShock 4 CHU-ZCT2U Charging Port Replacement: 手順 6、 3の画像 3
    • Peel off the black sticker on the charge port, using a pair of tweezers.
    • Unscrew the 4.50mm screw in the center of the port chip, using a Phillips-Head screwdriver.
    • Pull the charging port out with a pair of tweezers.
終わりに
16 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
David Seale
メンバー登録日: 10/09/17
1,714 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team S1-G5, Leahy Fall 2017 USF Tampa, Team S1-G5, Leahy Fall 2017人のメンバー
USFT-LEAHY-F17S1G5
3 メンバー
28のガイドは作成済み
9 件のコメント
Came in handy, since it’s hard enough to fix a JDM-030. Thanks!
Sunset Shimmer - 返信
Just did this on my JDM-030 (3rd generation DS4) as well. I would point out that the charge port for the JDM-030 (JDS-030?) looks slightly different and has more of a T-shape than the JDS-040, but aside from that, the instructions are functionally the same.
I will lastly add that having good tweezers is a must: the tweezers my jeweler’s drivers came with were crap and I had to go to the store to buy another pair. Make sure your equipment is solid before assembly.
Rob Barba - 返信
Can The JDS 040 work in a controller that uses the JDS 030?
RandyH - 返信
Tried to replace my usb port with a board that reads “1-981-33-31” from amazon. It was listed as JDS-40 and it does not work. In fact when plugged into a usb port on my laptop the ribbon cable gets noticeably hot but the controller will not power on.
Devin Sidell - 返信
Got the same problem. Any idea?
Jacco Veldscholten -
only wish we could change port to USB-C that would be awesome but impossible i think
DARKMATTER - 返信
Has anyone tried fixing the analog joystick on the new jds-055 I have fixed all other generations but this is the only one that I cant fix
SAM CORTEZ - 返信
Will the JDS-055 work with the JDS-050?
aaron boschman - 返信
where can i find a JDM-055
low bros - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 31
今までの合計 13,310
