Dell XPS M1730 M1730 RAM Replacement
はじめに
手順 1 に進むThis guide will show you how to replace Dell XPS M1730 M1730’s RAM.
Ground yourself by touching one of the metal connectors on the back of the computer.
Turn the computer over, loosen the captive screws on the memory module cover, and then remove the cover.
Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
Remove the module from the connector.
Ground yourself and install the new memory module:
Align the notch in the module edge connector with the tab in the connector slot.
Slide the module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it, and then proceed to replace the memory module cover.
Insert the battery into the battery bay, or connect the AC adapter to your computer and an electrical outlet.
Turn on the computer
Confirm the amount of memory installed in the computer: • Windows® XP – Right-click the My Computer icon on your desktop, then click Properties→ General. • 'Windows Vista™
