メインコンテンツにスキップ
Dell XPS 15 9510 Speakers Replacement
Bethany Wright
Bethany Wright とその他 6 人の作成者
最終更新日: January 7, 2025
15分
中レベル
多くの画像が必要
Audio issues or sound failure in the Dell XPS 15 9510 indicates that the speakers located on either side of the laptop may need replacement. There are no special skills involved in the removal of the speakers.
Before using this guide, make sure to review the troubleshooting page to ensure that the speaker doesn't have any driver or any other issues.
Make sure to power off your laptop completely and disconnect from any external power source before beginning the process.
必要な工具と部品
パーツ
ツール
もっと見る
  1. Dell XPS 15 9510 Speakers Replacement, Lower Case: 手順 1、 1の画像 1
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 Speakers Replacement: 手順 2、 1の画像 1
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 Speakers Replacement: 手順 3、 1の画像 1
    • Lift the back panel of the laptop off and set it aside.
  4. Dell XPS 15 9510 Speakers Replacement, Speakers: 手順 4、 3の画像 1 Dell XPS 15 9510 Speakers Replacement, Speakers: 手順 4、 3の画像 2 Dell XPS 15 9510 Speakers Replacement, Speakers: 手順 4、 3の画像 3
    • Remove the 4 pieces of black tape holding the speaker wire in place.
  5. Dell XPS 15 9510 Speakers Replacement: 手順 5、 2の画像 1 Dell XPS 15 9510 Speakers Replacement: 手順 5、 2の画像 2
    • Remove the four 2.5 mm screws holding the speakers in place using a Phillips #0 screwdriver.
  6. Dell XPS 15 9510 Speakers Replacement: 手順 6、 2の画像 1 Dell XPS 15 9510 Speakers Replacement: 手順 6、 2の画像 2
    この手順で使用する道具:
    • Lift the black tape that covers the power supply pin plug.
    • Remove the plug using a small pair of tweezers. Be sure to not damage any wiring.
  7. Dell XPS 15 9510 Speakers Replacement: 手順 7、 1の画像 1
    • Lift the speakers up from the securing pins.
  8. Dell XPS 15 9510 Speakers Replacement: 手順 8、 2の画像 1 Dell XPS 15 9510 Speakers Replacement: 手順 8、 2の画像 2
    • Begin removing the wire from the track on the computer body.
    • Now the speakers will be fully disconnected from the computer.
終わりに
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
2 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Bethany Wright
メンバー登録日: 07/13/23
439 ポイント
3のガイドは作成済み
チーム
IUPUI, Team 2-1, Harley Summer 2023 IUPUI, Team 2-1, Harley Summer 2023人のメンバー
IUPUI-HARLEY-SU23S2G1
4 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 10
今までの合計 265
