メインコンテンツにスキップ
Dell XPS 15 9510 Battery Replacement
Joseph Remondi
Joseph Remondi とその他 6 人の作成者
最終更新日: February 17, 2025
20分 - 1時間
中レベル
多くの画像が必要
Replacing the battery of a Dell XPS 15 9510 laptop is a straightforward task requiring only a few tools. The new battery constitutes nearly all of the cost of this repair, so if you are planning to order a replacement battery for this or any other laptop, it may be wise to remove the back panel of the laptop to ensure that the one you are ordering matches the existing one.
If the battery you are replacing is swollen, be sure to take appropriate precautions.
必要な工具と部品
修理キット
キットには、修理ガイドを完了するために必要な全ての部品とツールが含まれています。
パーツ
ツール
もっと見る
  1. Dell XPS 15 9510 Battery Replacement, Lower Case: 手順 1、 1の画像 1
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 Battery Replacement: 手順 2、 1の画像 1
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 Battery Replacement: 手順 3、 1の画像 1
    • Lift the back panel of the laptop off and set it aside.
  4. Dell XPS 15 9510 Battery Replacement, Battery: 手順 4、 2の画像 1 Dell XPS 15 9510 Battery Replacement, Battery: 手順 4、 2の画像 2
    • Using the small battery pull tab, disconnect the battery connector from the motherboard.
  5. Dell XPS 15 9510 Battery Replacement: 手順 5、 1の画像 1
    • Remove eight 2.5 mm from around the perimeter of the battery using a Phillips #0 screwdriver.
  6. Dell XPS 15 9510 Battery Replacement: 手順 6、 2の画像 1 Dell XPS 15 9510 Battery Replacement: 手順 6、 2の画像 2
    • There are many delicate components in the vicinity of the battery, so be extremely careful removing it
    • Remove the old battery from the laptop.
終わりに
5 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Joseph Remondi
メンバー登録日: 03/30/22
290 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 1-3, Mellen Spring 2022 UMass Dartmouth, Team 1-3, Mellen Spring 2022人のメンバー
UMASSD-MELLEN-S22S1G3
3 メンバー
5のガイドは作成済み
1件のガイドコメント
XPS 15 9510 states the battery (purchased from ifixit) is FAKE and the battery will not charge.
Jacques Aucamp - 返信
コメントを追加
統計データ:
過去 24時間: 15
過去 7 日: 93
過去 30 日: 381
今までの合計 6,849
