メインコンテンツにスキップ
Dell Vostro 3500 Hard Drive Replacement
Johnathan Hammond
Johnathan Hammond とその他 4 人の作成者
最終更新日: November 16, 2022
10 - 20 分
簡単
コミュニティメンバーによる寄稿ガイド
In this guide, we will show you how to remove and replace the Hard Drive.
必要な工具と部品
修理キット
キットには、この修理ガイドを完了するために必要な全ての部品とツールが含まれています。
パーツ
ツール
もっと見る
  1. Dell Vostro 3500 Hard Drive Replacement, Sliding the Battery Latch: 手順 1、 1の画像 1
    • Flip the computer over.
    • Slide the battery release latch to the unlock position.
  2. Dell Vostro 3500 Hard Drive Replacement, Sliding the Battery Release Latch: 手順 2、 1の画像 1
    • Slide the other battery release latch to the unlock position.
  3. Dell Vostro 3500 Hard Drive Replacement, Removing the Battery: 手順 3、 1の画像 1
    • Slide the battery and remove it from the computer.
  4. Dell Vostro 3500 Hard Drive Replacement, Remove the Screws: 手順 4、 1の画像 1
    • Turn the laptop over and remove two screws securing the service cover.
  5. Dell Vostro 3500 Hard Drive Replacement, Removing the Base Cover: 手順 5、 1の画像 1
    • Prise up the service cover and remove it from the computer. Clips along the edges can be snapped open except for those on the left hand edge (as shown in the photo) which have to be disengaged after all the others by romoving the cover in the direction shown.
    • On resassembly, insert the clips on the left hand edge then snap all te others home by applying firm pressure along the other edges of the cover.
  6. Dell Vostro 3500 Hard Drive Replacement, Remove the Screws: 手順 6、 1の画像 1
    • Remove the screws that secure the hard-drive assembly to the computer.
  7. Dell Vostro 3500 Hard Drive Replacement, Sliding the Hard-Drive Assembly: 手順 7、 1の画像 1
    • Slide the hard-drive assembly towards the center of the computer.
  8. Dell Vostro 3500 Hard Drive Replacement, Lifting the Hard-Drive Assembly: 手順 8、 1の画像 1
    • Lift the hard-drive assembly up and away from the computer.
  9. Dell Vostro 3500 Hard Drive Replacement, Remove the Screws: 手順 9、 1の画像 1
    • Remove the screws that secure the hard-drive bracket to the hard drive
  10. Dell Vostro 3500 Hard Drive Replacement, Remove the Hard-Drive Adapter: 手順 10、 1の画像 1
    • Remove the hard-drive adapter from the hard-drive assembly.
  11. Dell Vostro 3500 Hard Drive Replacement, Lifting the Hard-Drive Bracket: 手順 11、 1の画像 1
    • Lift the hard-drive bracket up and away from the hard drive.
終わりに
6 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Johnathan Hammond
メンバー登録日: 02/28/18
45,237 ポイント
408のガイドは作成済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
43 メンバー
1,985のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 42
今までの合計 5,492
