メインコンテンツにスキップ
Dell Latitude E6510 WWAN Card Replacement
Kolin Doyle
Kolin Doyle とその他 2 人の作成者
最終更新日: March 4, 2024
2分
簡単
高画質の画像が必要
空欄の手順
If your laptop cannot connect to the cellular network it may be due to the WWAN card. Follow this guide to help properly replace the WWAN card.
必要な工具と部品
ツール
  • Spudger
    Spudger
  • JIS #1
  1. Dell Latitude E6510 WWAN Card Replacement, WWAN Card: 手順 1、 2の画像 1 Dell Latitude E6510 WWAN Card Replacement, WWAN Card: 手順 1、 2の画像 2
    • Remove the 8mm screw in the middle from the laptop with the J1 screwdriver.
    • Then slide the back plate off.
  2. Dell Latitude E6510 WWAN Card Replacement: 手順 2、 1の画像 1
    • Remove the antenna wires from the WWAN card using a plastic opening tool.
    • Use the same Phillips screwdriver to remove the screw holding the WWAN card in place.
    • The WWAN card is missing in this model.
    Totally wrong!! The wifi card installs under the similar cover on the, *other side* of the machine! What you're showing there is the location for the WWAN card. Those cards are for cellular tyoe communications, which are rarely used by in day-to-day laptop owners.
    John - 返信
終わりに
作成者
2人の作成者と共同で作成されました。
Kolin Doyle
メンバー登録日: 11/06/17
500 ポイント
4のガイドは作成済み
チーム
Baylor, Team S8-G4, Johnson Fall 2017 Baylor, Team S8-G4, Johnson Fall 2017人のメンバー
BU-JOHNSON-F17S8G4
1 メンバー
4のガイドは作成済み
2 件のコメント
This article is incorrect. The slot being showed in the diagram is for a WWAN, which is used for connecting to a a cellular network (3G, 4G, LTE, etc). The actual wifi card is tucked under the gray plastic cover at the top right (looking at the first photo) above the CPU fan.
Jason - 返信
Holy !&&* this is misleading. All of this “Kolin Doyle” person’s guides are idiotic and basic, everybody knows how to take a %#*@ battery out of a laptop! And as Jason said, the guide is totally incorrect, that’s the wrong %#*@ slot for gosh sake; that slot is for a WWAN card that allows connecting to a cellular network, the WiFi card is under the plastic cover on the right, above the heatpipes, and you can even see an antenna cable! Please, mods, delete this incorrect guide and the rest of the guides this person has published; the Latitude e6510 is the easiest laptop to service that I personally own and this guy is making it look hard.
Alex Matthiessen - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 37
今までの合計 2,442
