Dell Latitude E4200 CMOS (CR2032 coin-cell time battery) Replacement
3 - 5 分
中レベル
高画質の画像が必要
多くの画像が必要
コミュニティメンバーによる寄稿ガイド
より良い紹介部分
必要な工具と部品
Pry up the coin-cell battery to release the double-sided adhesive tape on the bottom.
Lift the coin-cell battery out of the computer.
Disconnect the battery cable from the system board.
Connect the coin-cell battery cable to the system board.
Insert the coin-cell battery into the computer.
If you are re-installing the old coin-cell battery, press down to seal the tape on the bottom.
If you are installing a new coin-cell battery, remove the adhesive backing from the battery, and slide the battery under the tab. Press to seal the tape on the bottom.
もう少しです!
ゴール
