Dell Inspiron n5110 heat sink and thermal paste replacement
はじめに
手順 1 に進むIf your laptop overheat, you must open it and clean the Heat-Sink system. This video will show you how to do this.
ビデオの概要
Switch-off the laptop and remove the battery.
To remove the keyboard lift it from one side by using cutter. Now open 4x locking clips at the upper side on the keyboard.
Unscrew 5x M2.5x5.0 screws.
Disconnect the Loudspeakers cable connector.
Remove the Daughter Bluetooth board.
Start removing the mother board by lifting from the right side (near to the DVD drive connector).
Be careful, there are connectors between mother board and another two additional small boards (charging port board and USB connectors, WiFi card slot board).
Now put a new thermal paste / compose to the CPU. Cover all the surface of the CPU crystal with the thermo-compose.
19 の人々がこのガイドを完成させました。
2 件のコメント
Which thermal paste would you recommend?
PinupSquid - 返信
Done! It works, now my laptop is as new!
