メインコンテンツにスキップ
Dell Inspiron i3558-5500BLK Internal Fan Replacement
Nathan Ybanez
Nathan Ybanez とその他 3 人の作成者
最終更新日: July 20, 2024
10分
中レベル
This guide will show you how to remove and replace the internal fan for the Dell Inspiron i3558-5500BLK Laptop.
WARNING: Static electricity can damage the electronic components of this model. Before
beginning these procedures, discharge any built up static electricity by briefly touching a grounded
metal object. For example, you can touch the metal frame inside the case of most desktop computers, or wear an anti-static wristband.
必要な工具と部品
ツール
  • Phillips #0 Screwdriver
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
もっと見る
  1. Dell Inspiron i3558-5500BLK Internal Fan Replacement, Keyboard: 手順 1、 2の画像 1 Dell Inspiron i3558-5500BLK Internal Fan Replacement, Keyboard: 手順 1、 2の画像 2
    • With the laptop open and facing upright, use the Spudger to pull at the notches shown in the image.
  2. Dell Inspiron i3558-5500BLK Internal Fan Replacement: 手順 2、 3の画像 1 Dell Inspiron i3558-5500BLK Internal Fan Replacement: 手順 2、 3の画像 2 Dell Inspiron i3558-5500BLK Internal Fan Replacement: 手順 2、 3の画像 3
    • Gently turn the keyboard over to reveal the ribbon cable underneath. Remove the cable from the motherboard by lifting the white release tab and gently pulling the cable away from the socket.
    • Lift the keyboard away from the baseboard to remove.
  3. Dell Inspiron i3558-5500BLK Internal Fan Replacement, Battery: 手順 3、 3の画像 1 Dell Inspiron i3558-5500BLK Internal Fan Replacement, Battery: 手順 3、 3の画像 2 Dell Inspiron i3558-5500BLK Internal Fan Replacement, Battery: 手順 3、 3の画像 3
    • With the back of the laptop facing upright, press the switch shown to loosen the battery and remove it.
  4. Dell Inspiron i3558-5500BLK Internal Fan Replacement, Back Cover: 手順 4、 2の画像 1 Dell Inspiron i3558-5500BLK Internal Fan Replacement, Back Cover: 手順 4、 2の画像 2
    • With the laptop facing upright - remove the ribbon cable from the optical drive by lifting the white release tab and gently pulling the cable away from the socket.
  5. Dell Inspiron i3558-5500BLK Internal Fan Replacement: 手順 5、 2の画像 1 Dell Inspiron i3558-5500BLK Internal Fan Replacement: 手順 5、 2の画像 2
    • Slide the optical drive out of the port on the right-side of the laptop.
  6. Dell Inspiron i3558-5500BLK Internal Fan Replacement: 手順 6、 3の画像 1 Dell Inspiron i3558-5500BLK Internal Fan Replacement: 手順 6、 3の画像 2 Dell Inspiron i3558-5500BLK Internal Fan Replacement: 手順 6、 3の画像 3
    • With the back of the laptop facing upright, remove the following screws:
    • Ten 0.5 mm Phillips screws from the backboard
    • One 0.2 mm Phillips screw from the battery port
    • Three 0.1 mm Phillips screws from the optical drive slot.
  7. Dell Inspiron i3558-5500BLK Internal Fan Replacement: 手順 7、 2の画像 1 Dell Inspiron i3558-5500BLK Internal Fan Replacement: 手順 7、 2の画像 2
    • Gently pry the back cover from the opposite side of the battery to reveal the internal components.
  8. Dell Inspiron i3558-5500BLK Internal Fan Replacement, Internal Fan: 手順 8、 3の画像 1 Dell Inspiron i3558-5500BLK Internal Fan Replacement, Internal Fan: 手順 8、 3の画像 2 Dell Inspiron i3558-5500BLK Internal Fan Replacement, Internal Fan: 手順 8、 3の画像 3
    • Identify the fan assembly as shown in the image.
    • Remove the power cable by gently pulling it away from the fixture.
  9. Dell Inspiron i3558-5500BLK Internal Fan Replacement: 手順 9、 2の画像 1 Dell Inspiron i3558-5500BLK Internal Fan Replacement: 手順 9、 2の画像 2
    • Loosen the three 2 mm Phillips heatsink screws.
    • Remove the 0.5 mm Phillips fastener screw, identified by the red circle.
    • Remove the fan from the motherboard.
  10. Dell Inspiron i3558-5500BLK Internal Fan Replacement: 手順 10、 3の画像 1 Dell Inspiron i3558-5500BLK Internal Fan Replacement: 手順 10、 3の画像 2 Dell Inspiron i3558-5500BLK Internal Fan Replacement: 手順 10、 3の画像 3
    • Unfasten the screws shown in the image to remove the cover and heatsink from the fan unit.
終わりに
作成者
3人の作成者と共同で作成されました。
Nathan Ybanez
メンバー登録日: 09/27/17
622 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team S9-G5, Banghart Fall 2017 Cal Poly, Team S9-G5, Banghart Fall 2017人のメンバー
CPSU-BANGHART-F17S9G5
4 メンバー
19のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 397
