Dell Inspiron 910 Web Camera Replacement
はじめに
手順 1 に進むIf your Dell Inspiron 910 web camera isn’t showing a clear image, or no image at all, you may have a malfunctioning camera. Before replacing your camera, inspect the lens for debris or smudges, and clean with a microfiber cloth. If the problem persists, follow these steps to replace your web camera. This guide requires a plastic opening tool, a phillips screwdriver, and flathead screwdriver to follow. Before using this guide, make sure the laptop is powered off completely to prevent any further damage and the necessary tools are accessible.
Using a plastic opening tool, pry the front silver bezel away from the colored plastic shell.
Using a Phillips #00 screwdriver, remove the two small screws located above the screen at the center of the lid. Set these screws aside for reassembly.
