メインコンテンツにスキップ
Dell Inspiron 8600 Touch Pad Replacement
John Nesthus
John Nesthus とその他 8 人の作成者
最終更新日: January 10, 2025
1 - 2 時間
中レベル
アクションショット
多くの画像が必要
ツールが不適切
空欄の手順
より良い紹介部分
In this guide, you will learn how to replace the touchpad on the Dell Inspiron 8600. The touchpad is used to scroll and click on links and items that are being presented on your screen without this function working properly your computer is ineffective.
Before you start the repair, make sure your laptop is powered off and it is unplugged from the charger.
必要な工具と部品
ツール
  1. Dell Inspiron 8600 Touch Pad Replacement, Battery: 手順 1、 1の画像 1
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Touch Pad Replacement, Hinge Cover: 手順 2、 3の画像 1 Dell Inspiron 8600 Touch Pad Replacement, Hinge Cover: 手順 2、 3の画像 2 Dell Inspiron 8600 Touch Pad Replacement, Hinge Cover: 手順 2、 3の画像 3
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
  3. Dell Inspiron 8600 Touch Pad Replacement: 手順 3、 1の画像 1
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
  4. Dell Inspiron 8600 Touch Pad Replacement, Keyboard: 手順 4、 3の画像 1 Dell Inspiron 8600 Touch Pad Replacement, Keyboard: 手順 4、 3の画像 2 Dell Inspiron 8600 Touch Pad Replacement, Keyboard: 手順 4、 3の画像 3
    • Using the Phillips #1 remove the screws at the top of the keyboard as indicated.
    • Do not just lift up. There is a tab underneath the keyboard that is still connected to the mother board.
    • You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
    • The keyboard should be easily removable at this point.
  5. Dell Inspiron 8600 Touch Pad Replacement, Display Module: 手順 5、 2の画像 1 Dell Inspiron 8600 Touch Pad Replacement, Display Module: 手順 5、 2の画像 2
    • Flip the laptop over and remove the indicated screws.
    • Flip the laptop back over.
    • Find the two places where the display module is attached to the base of the computer.
  6. Dell Inspiron 8600 Touch Pad Replacement: 手順 6、 1の画像 1
    • Disconnect the video card from the display module by gently lifting upwards on the black tab.
  7. Dell Inspiron 8600 Touch Pad Replacement: 手順 7、 2の画像 1 Dell Inspiron 8600 Touch Pad Replacement: 手順 7、 2の画像 2
    • Lift the display module directly upwards from the base of the computer.
  8. Dell Inspiron 8600 Touch Pad Replacement: 手順 8、 1の画像 1
    • Now remove the display module.
  9. Dell Inspiron 8600 Touch Pad Replacement, Touch Pad: 手順 9、 1の画像 1
    • Remove the palm rest assembly that secures the touch pad from the device.
終わりに
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
作成者
8人の作成者と共同で作成されました。
John Nesthus
メンバー登録日: 04/13/11
186 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 18-22, Garner Spring 2011 Cal Poly, Team 18-22, Garner Spring 2011人のメンバー
CPSU-GARNER-S11S18G22
4 メンバー
16のガイドは作成済み
0ガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 20
今までの合計 3,098
