メインコンテンツにスキップ
Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement
Delia Padilla
Delia Padilla とその他 2 人の作成者
最終更新日: December 28, 2022
4分
中レベル
This is Dell Inspiron 17" 7786 2-in-1 heatsink replacement guide.
If the device has a loud fan noise, is hot to the touch, and turns off or restarts after a few minutes of being on, a faulty heatsink may be the cause.
Similar to the fan, you can hear a loud, constantly running fan. This could signal a dust accumulation in the heatsink. Without the heatsink, the fan is working harder than normal to compensate for the faulty heatsink. You may need to take the computer apart to use compressed air to clean the heatsink out or a microfiber cloth.
The computer case may feel hot to the touch. If you have fan noise and ruled out malware or other types of software problems, then a faulty or clogged heatsink could be the cause. You can also download temperature utility applications on your device to check the temperature.
When the temperature reaches a critical level, the system will shut itself down, restart itself or will stop randomly. This is to prevent permanent damage. The system shutdown will also show an error message. This may be a sign of a faulty, clogged or dead heatsink.
Replacement is recommended.
必要な工具と部品
ツール
  1. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement, Base Cover: 手順 1、 2の画像 1 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement, Base Cover: 手順 1、 2の画像 2
    • Remove the eight M2 5mm screws that secure the base cover using a Phillips #0 screwdriver.
  2. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 手順 2、 2の画像 1 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 手順 2、 2の画像 2
    • Loosen the three captive screws that secure the base closer to the hinges.
    • Do not attempt to remove the three captive screws! You need only to loosen them. They're supposed to stay on the base cover.
  3. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 手順 3、 3の画像 1 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 手順 3、 3の画像 2 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 手順 3、 3の画像 3
    • Carefully pry the base cover using an iFixit opening tool in the crevice near the hinges. Guide the pick along the edges and slightly lift upwards as you go along.
    • Do not start from the speaker end of the edges when opening, or you may cause further damage to your device!
  4. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 手順 4、 3の画像 1 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 手順 4、 3の画像 2 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 手順 4、 3の画像 3
    • Carefully remove the base cover from the laptop.
  5. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement, Fan: 手順 5、 2の画像 1 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement, Fan: 手順 5、 2の画像 2
    • Gently remove the I/O cable.
  6. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 手順 6、 2の画像 1 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 手順 6、 2の画像 2
    • Remove the fan cable from the motherboard.
  7. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 手順 7、 1の画像 1
    • Remove two 3 mm screws that secure the fan using a Phillips #0 screwdriver.
  8. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 手順 8、 2の画像 1 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 手順 8、 2の画像 2
    • There is a little piece of tape/sticker on the fan that connects it to the heat sink. Gently remove this.
    • Lift the fan off the palm rest assembly.
  9. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement, Heatsink: 手順 9、 2の画像 1 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement, Heatsink: 手順 9、 2の画像 2
    • Loosen seven 3 mm captive screws securing the heatsink to the motherboard using a Phillips #0 screwdriver.
  10. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 手順 10、 3の画像 1 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 手順 10、 3の画像 2 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 手順 10、 3の画像 3
    • Lift the heatsink off the motherboard.
終わりに
作成者
2人の作成者と共同で作成されました。
Delia Padilla
メンバー登録日: 08/23/22
588 ポイント
5のガイドは作成済み
チーム
Gateway, Team 1-3, Class Fall 2022 Gateway, Team 1-3, Class Fall 2022人のメンバー
GCC-CLASS-F22S1G3
4 メンバー
15のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 23
今までの合計 128
