メインコンテンツにスキップ
Dell Chromebook 5190 I/O board Replacement
Denise Cano
Denise Cano とその他 2 人の作成者
最終更新日: June 20, 2022
1 - 5 分
簡単
This guide will aid you in replacing your Dell Chromebook 5190 I/O board.
The Dell Chromebook 5190 was released alongside its sister model Dell Chromebook 5190 2-in-1. This guide will focus on the 5190 model that lacks a touchscreen.
The I/O board on your laptop helps physically connect external devices to your computer. If you are having issues with your computer identifying external devices when connected, try the Dell Chromebook 5190 troubleshooting page for possible solutions before replacing the I/O. If you are still experiencing these issues after troubleshooting, you may need a I/O board replacement.
Please make sure your laptop is off before beginning, and remove all cables or devices populating your laptop ports.
必要な工具と部品
これらのリンクを通じて購入すると、iFixit は手数料を得ます。
  1. Dell Chromebook 5190 I/O board Replacement, Battery: 手順 1、 1の画像 1
    • Before starting, please make sure you have disconnected and removed all devices populating the laptop's ports.
    • Remove the nine M2.5x7.5 screws located on the bottom side of the laptop.
  2. Dell Chromebook 5190 I/O board Replacement: 手順 2、 3の画像 1 Dell Chromebook 5190 I/O board Replacement: 手順 2、 3の画像 2 Dell Chromebook 5190 I/O board Replacement: 手順 2、 3の画像 3
    • Be cautious, the following instructions are to prevent cracking the base cover.
    • With the opening tool, pry open the upper left corner by the laptop hinge.
    • With the opening tool, pry open the upper right corner by the laptop hinge.
    • Lift off base cover.
  3. Dell Chromebook 5190 I/O board Replacement: 手順 3、 2の画像 1 Dell Chromebook 5190 I/O board Replacement: 手順 3、 2の画像 2
    • Unscrew and remove the M2x3 screw holding the silver metal brackets labeled "Battery Bracket" located on the top left side of the battery.
    • Unscrew and remove the M2x3 screw holding the silver metal brackets labeled "Battery Bracket" located on the top right side of the battery.
  4. Dell Chromebook 5190 I/O board Replacement: 手順 4、 2の画像 1 Dell Chromebook 5190 I/O board Replacement: 手順 4、 2の画像 2
    • Remove the clear adhesive tape on the system board from the battery cable from where it's seated above the battery.
    • Pull out the keyboard cable toward you to disconnect it.
  5. Dell Chromebook 5190 I/O board Replacement: 手順 5、 2の画像 1 Dell Chromebook 5190 I/O board Replacement: 手順 5、 2の画像 2
    • Remove the black adhesive tape on the system board from the battery cable.
    • Dismount the cable from where it's seated above the battery.
  6. Dell Chromebook 5190 I/O board Replacement: 手順 6、 3の画像 1 Dell Chromebook 5190 I/O board Replacement: 手順 6、 3の画像 2 Dell Chromebook 5190 I/O board Replacement: 手順 6、 3の画像 3
    • Unscrew and remove the four M2x3 screws on each corner of the battery.
    • Dismount the battery.
  7. Dell Chromebook 5190 I/O board Replacement, I/O board: 手順 7、 2の画像 1 Dell Chromebook 5190 I/O board Replacement, I/O board: 手順 7、 2の画像 2
    • Disconnect the first purple I/O cable by lifting upwards and pulling away from the I/O connector.
  8. Dell Chromebook 5190 I/O board Replacement: 手順 8、 2の画像 1 Dell Chromebook 5190 I/O board Replacement: 手順 8、 2の画像 2
    • Disconnect the second purple I/O cable by lifting upwards and pulling away from the I/O connector.
  9. Dell Chromebook 5190 I/O board Replacement: 手順 9、 3の画像 1 Dell Chromebook 5190 I/O board Replacement: 手順 9、 3の画像 2 Dell Chromebook 5190 I/O board Replacement: 手順 9、 3の画像 3
    • Unscrew the two (M2x4) screws on the I/O bracket.
    • Lift off the I/O bracket.
  10. Dell Chromebook 5190 I/O board Replacement: 手順 10、 2の画像 1 Dell Chromebook 5190 I/O board Replacement: 手順 10、 2の画像 2
    • Unscrew the three (M2x4) screws on the I/O board.
    • Dismount the I/O board.
終わりに
作成者
2人の作成者と共同で作成されました。
Denise Cano
メンバー登録日: 02/10/22
617 ポイント
4のガイドは作成済み
チーム
Gateway, Team 1-3, Pee Spring 2022 Gateway, Team 1-3, Pee Spring 2022人のメンバー
GCC-PEE-S22S1G3
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 6
今までの合計 243
