Dell Chromebook 3100 2-in-1 Touchpad Replacement
はじめに
手順 1 に進むThis guide will tell you step-by-step how to replace the keypad in the Dell Chromebook 3100 2-in-1 and tools are needed to do it.
Before beginning, make sure to power off the laptop completely and disconnect from any external power source.
To start replacing the touch-pad, unscrew the 9 Phillips head screws holding down the rear cover (It is recommended to use a PH1 bit for the screwdriver).
Once all 9 screws are removed, wedge an iFixit Opening Tool in the gap between the rear cover and the rest of the laptop.
Once in, gently run the tool around the perimeter of the rear cover. You will hear popping sounds as the plastic tabs detach.
After enough tabs have been detached, simply pull off the rear cover.
