メインコンテンツにスキップ
Dell Chromebook 3100 2-in-1 Speaker Replacement
M Ali
M Ali とその他 3 人の作成者
最終更新日: December 27, 2021
5分
中レベル
If the sound is dull or nonexistent from your Dell Chromebook 3100 2-in-1 laptop, use this guide to remove and replace your speakers.
Before using this guide, check the speaker for blockage that may be interfering with the sound. Usually, dust and debris can be cleared by a small dust blower. Make sure to check that the volume is not muted to confirm it needs replacing.
To begin this guide, check that the Chromebook’s power is off and disconnected from any power source.
It is not necessary to remove the battery; instead, the battery connector can be disconnected to isolate power to the system.
必要な工具と部品
パーツ
ツール
もっと見る
  1. Dell Chromebook 3100 2-in-1 Speaker Replacement, Back Cover: 手順 1、 2の画像 1 Dell Chromebook 3100 2-in-1 Speaker Replacement, Back Cover: 手順 1、 2の画像 2
    • Using a Phillips #1 screwdriver, remove all nine of the 5 mm screws from the back cover.
  2. Dell Chromebook 3100 2-in-1 Speaker Replacement: 手順 2、 2の画像 1 Dell Chromebook 3100 2-in-1 Speaker Replacement: 手順 2、 2の画像 2
    • Use the opening tool to pry the back cover off of the device.
  3. Dell Chromebook 3100 2-in-1 Speaker Replacement, Battery: 手順 3、 2の画像 1 Dell Chromebook 3100 2-in-1 Speaker Replacement, Battery: 手順 3、 2の画像 2
    • Disconnect the battery cable from the connector on the system board.
  4. Dell Chromebook 3100 2-in-1 Speaker Replacement: 手順 4、 3の画像 1 Dell Chromebook 3100 2-in-1 Speaker Replacement: 手順 4、 3の画像 2 Dell Chromebook 3100 2-in-1 Speaker Replacement: 手順 4、 3の画像 3
    • Using a Phillips #1 screwdriver, remove the three 4 mm screws that secure the battery.
    • Remove the adhesive tape that secures the battery in place.
  5. Dell Chromebook 3100 2-in-1 Speaker Replacement: 手順 5、 2の画像 1 Dell Chromebook 3100 2-in-1 Speaker Replacement: 手順 5、 2の画像 2
    • Carefully remove the battery from the device.
  6. Dell Chromebook 3100 2-in-1 Speaker Replacement, Speaker: 手順 6、 2の画像 1 Dell Chromebook 3100 2-in-1 Speaker Replacement, Speaker: 手順 6、 2の画像 2
    • Remove adhesive tape that secures the speaker cable.
    • Disconnect the speaker cable from the connector on the system board.
  7. Dell Chromebook 3100 2-in-1 Speaker Replacement: 手順 7、 2の画像 1 Dell Chromebook 3100 2-in-1 Speaker Replacement: 手順 7、 2の画像 2
    • Remove the speaker cable from the retention clips.
  8. Dell Chromebook 3100 2-in-1 Speaker Replacement: 手順 8、 2の画像 1 Dell Chromebook 3100 2-in-1 Speaker Replacement: 手順 8、 2の画像 2
    • Lift and remove the speakers from the device.
終わりに
作成者
3人の作成者と共同で作成されました。
M Ali
メンバー登録日: 11/03/21
313 ポイント
2のガイドは作成済み
チーム
Gateway, Team 1-1, Pee Fall 2021 Gateway, Team 1-1, Pee Fall 2021人のメンバー
GCC-PEE-F21S1G1
5 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 8
今までの合計 326
