メインコンテンツにスキップ
Cruiser Bike Rear Wheel Replacement
Erin Heimburge
Erin Heimburge とその他 13 人の作成者
最終更新日: June 29, 2023
15 - 30 分
中レベル
高画質の画像が必要
This guide will walk you through the process of replacing the rear wheel of your cruiser bike. You will need to replace your wheel if it is flat or continues going flat. This process can be tricky, considering the parts associated with the rear wheel. Make sure you have the correct tools for the job and follow the directions strictly. The most strenuous part of this repair is flipping the bike.
  1. Cruiser Bike Rear Wheel Replacement, Rear Wheel: 手順 1、 1の画像 1
    • Flip your bike so the seat and handlebars are on the ground.
    • This will make it easier to access tire.
  2. Cruiser Bike Rear Wheel Replacement: 手順 2、 1の画像 1
    • Slip the chain onto the crank and rear cog. Then insert wheel into rear drop-outs.
    • Make sure that the chain is on the correct side of the wheel.
    • Handle the chain carefully to ensure a successful tire replacement.
  3. Cruiser Bike Rear Wheel Replacement: 手順 3、 1の画像 1
    • Tighten brake strap using screwdriver and 10 mm socket wrench.
    • Hold the nut on the inside (near the spokes) with wrench as you tighten the screw with the screwdriver.
    • You will know the socket wrench is has finished tightening when you feel resistance.
  4. Cruiser Bike Rear Wheel Replacement: 手順 4、 1の画像 1
    • Center the wheel and pull back to tighten the chain.
    • If the bike wheel is unusable use tire levers to remove tire.
  5. Cruiser Bike Rear Wheel Replacement: 手順 5、 1の画像 1
    • With the wheel pulled back, tighten the two axle nuts using the 15 mm socket wrench.
    • Tighten the non-drive side (side without the chain) first.
    • The wheel will angle as you tighten. Keep it centered with your hand as you finish tightening both axle nuts.
    • Use a tire pump to make sure the tire is full of air and ready to ride.
終わりに
2 の人々がこのガイドを完成させました。
作成者
13人の作成者と共同で作成されました。
Erin Heimburge
メンバー登録日: 07/11/13
36 ポイント
1ガイドが承認済み
チーム
UC Santa Barbara, Team 2-1, Bradley Spring 2013 UC Santa Barbara, Team 2-1, Bradley Spring 2013人のメンバー
UCSB-BRADLEY-S13S2G1
4 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 32
今までの合計 11,299
