メインコンテンツにスキップ
Canon Powershot Pro1 LCD Screen Replacement
Seana Meegan
Seana Meegan とその他 3 人の作成者
最終更新日: May 7, 2024
35分
難しい
ツールが不適切
If the LCD of your Canon Powershot Pro1, follow this guide. The LCD provides the user with several features; such as the ability to view pictures and changing settings. If your LCD is damaged, your images may appear distorted. In this case, it is important to replace your LCD screen. Be sure to use ESD safe tools and remove the battery prior to disassembly. Also, be careful when removing the cables. They are essential to the operation of the LCD.
必要な工具と部品
ツール
もっと見る
  1. Canon Powershot Pro1 LCD Screen Replacement, Battery: 手順 1、 1の画像 1
    • Locate the battery compartment cover on the right hand side of the camera. The cover features the text: “CF/BATT.OPEN”.
  2. Canon Powershot Pro1 LCD Screen Replacement: 手順 2、 1の画像 1
    • There is an arrow beside the text. Using your hands, slide the cover in the direction of this arrow.
  3. Canon Powershot Pro1 LCD Screen Replacement: 手順 3、 1の画像 1
    • Pull the cover toward you. After doing so you will see the battery sitting inside the compartment.
  4. Canon Powershot Pro1 LCD Screen Replacement: 手順 4、 1の画像 1
    • Press the orange battery lock inside the compartment.
    • Remove the battery.
    • This photo show the battery compartment after the battery has been removed.
  5. Canon Powershot Pro1 LCD Screen Replacement, LCD screen: 手順 5、 1の画像 1
    • Open up the LCD screen.
  6. Canon Powershot Pro1 LCD Screen Replacement: 手順 6、 2の画像 1 Canon Powershot Pro1 LCD Screen Replacement: 手順 6、 2の画像 2
    • Remove the 1.2 mm Phillips #0 screws on the left and right side of the LCD.
    • Using the Phillips #000 screwdriver, remove the screws on the right (you need to rotate the screen to access the screws on the right, and you will see one on each corner).
  7. Canon Powershot Pro1 LCD Screen Replacement: 手順 7、 1の画像 1
    • Remove the back cover of the LCD screen (has “Canon” written on it).
  8. Canon Powershot Pro1 LCD Screen Replacement: 手順 8、 3の画像 1 Canon Powershot Pro1 LCD Screen Replacement: 手順 8、 3の画像 2 Canon Powershot Pro1 LCD Screen Replacement: 手順 8、 3の画像 3
    この手順で使用する道具:
    • Now you will see an exposed circuit board and the backside of the LCD.
    • Fold back the plastic covering and remove the highlighted ribbon cables with tweezers.
  9. Canon Powershot Pro1 LCD Screen Replacement: 手順 9、 1の画像 1
    • Using the nylon spudger, pry the LCD off the screen cover.
    • You can now separate the LCD from the camera.
    • Don't use a metal spudger as this could cause damage to the device.
終わりに
作成者
3人の作成者と共同で作成されました。
Seana Meegan
メンバー登録日: 09/06/19
677 ポイント
5のガイドは作成済み
チーム
University of Alabama, Team S1-G1, Bedsole Fall 2019 University of Alabama, Team S1-G1, Bedsole Fall 2019人のメンバー
UA-BEDSOLE-F19S1G1
3 メンバー
10のガイドは作成済み
コメント 1 件
Hi, where do I get a replacement lcd screen for this is camera?
Dog EatDog - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 13
今までの合計 906
