メインコンテンツにスキップ
Blink Video Doorbell Speaker Replacement
LisbethRivas_
LisbethRivas_ とその他 4 人の作成者
最終更新日: January 3, 2025
15 - 20 分
中レベル
The Blink Video Doorbell is a doorbell to provide extra security to your residence by giving you an accessible view whenever necessary. The speaker is a key function of the device. It allows you to be able to hear during the video and relay a message back through the device. Refer to the troubleshooting page if there are issues with the speaker which could be connected to causes such as debris. If you need to take out the speaker, use this guide to remove and replace the speaker.
必要な工具と部品
これらのリンクを通じて購入すると、iFixit は手数料を得ます。
  1. Blink Video Doorbell Speaker Replacement, Battery: 手順 1、 3の画像 1 Blink Video Doorbell Speaker Replacement, Battery: 手順 1、 3の画像 2 Blink Video Doorbell Speaker Replacement, Battery: 手順 1、 3の画像 3
    • Push the opening key into the small opening with the two gray buttons on the bottom of the device.
    • The device will click off the mount.
    • Push the device up from the mount and slide it off.
  2. Blink Video Doorbell Speaker Replacement: 手順 2、 3の画像 1 Blink Video Doorbell Speaker Replacement: 手順 2、 3の画像 2 Blink Video Doorbell Speaker Replacement: 手順 2、 3の画像 3
    • Use your finger to slide the gray tab, located near the bottom of the device, upwards.
    • Remove the battery cover.
  3. Blink Video Doorbell Speaker Replacement: 手順 3、 3の画像 1 Blink Video Doorbell Speaker Replacement: 手順 3、 3の画像 2 Blink Video Doorbell Speaker Replacement: 手順 3、 3の画像 3
    • Remove the right battery by pushing the positive end down and pulling the battery out toward yourself.
    • Repeat the procedure for the left battery.
    • Do not mix used and new batteries or batteries of different types (for example, lithium and alkaline batteries).
  4. Blink Video Doorbell Speaker Replacement, Back Panel: 手順 4、 3の画像 1 Blink Video Doorbell Speaker Replacement, Back Panel: 手順 4、 3の画像 2 Blink Video Doorbell Speaker Replacement, Back Panel: 手順 4、 3の画像 3
    • Remove the two 6 mm screws in the battery compartment using a JIS #1 screwdriver.
    • Remove the two 7 mm screws above the battery compartment using a JIS #1 screwdriver.
    • Starting from the bottom of the device, pry the back plate away from the rest of the doorbell.
  5. Blink Video Doorbell Speaker Replacement, Speaker: 手順 5、 3の画像 1 Blink Video Doorbell Speaker Replacement, Speaker: 手順 5、 3の画像 2 Blink Video Doorbell Speaker Replacement, Speaker: 手順 5、 3の画像 3
    • Remove the three 6 mm screws from the upper part of the motherboard using a JIS #1 screwdriver.
    • Use an opening tool to release the motherboard from the device.
  6. Blink Video Doorbell Speaker Replacement: 手順 6、 3の画像 1 Blink Video Doorbell Speaker Replacement: 手順 6、 3の画像 2 Blink Video Doorbell Speaker Replacement: 手順 6、 3の画像 3
    • Use tweezers to detach the white connector from the adapter on the motherboard.
    • Remove the speaker.
終わりに
作成者
4人の作成者と共同で作成されました。
LisbethRivas_
メンバー登録日: 10/18/24
87 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 1-1, Konn Fall 2024 UMass Dartmouth, Team 1-1, Konn Fall 2024人のメンバー
UMASSD-KONN-F24S1G1
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 10
今までの合計 96
