メインコンテンツにスキップ
BLU Life XL Headphone Port Replacement
Matthew Hook
Matthew Hook とその他 2 人の作成者
最終更新日: May 10, 2019
40分
難しい
間違いの指摘
This guide is used to show how to replace the headphone port on the BLU Life XL. The headphone port may need replaced if your headphones work with other devices, but not in your BLU Life XL. Soldering experience is suggested.
必要な工具と部品
ツール
もっと見る
  1. BLU Life XL Headphone Port Replacement, Volume Control Buttons: 手順 1、 3の画像 1 BLU Life XL Headphone Port Replacement, Volume Control Buttons: 手順 1、 3の画像 2 BLU Life XL Headphone Port Replacement, Volume Control Buttons: 手順 1、 3の画像 3
    • Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
    • Remove the rear cover using your hands at the lip on the device back cover. No tools required.
    • Remove the battery by lifting the lower edge of the battery up first.
  2. BLU Life XL Headphone Port Replacement: 手順 2、 2の画像 1 BLU Life XL Headphone Port Replacement: 手順 2、 2の画像 2
    • Remove the 12x3mm screws from the rear plate using the Phillips#000 screwdriver.
  3. BLU Life XL Headphone Port Replacement: 手順 3、 2の画像 1 BLU Life XL Headphone Port Replacement: 手順 3、 2の画像 2
    • Firmly press the prying tool into the gap between the front glass and rear plate. This gap is located on all sides of the phone.
    • Run the prying tool around the entire phone separating the rear plate from the frame.
  4. BLU Life XL Headphone Port Replacement: 手順 4、 3の画像 1 BLU Life XL Headphone Port Replacement: 手順 4、 3の画像 2 BLU Life XL Headphone Port Replacement: 手順 4、 3の画像 3
    • Gently remove the tape covering the volume control buttons. The tape is located near the top left of the cavity for the battery.
    • Replace the component and reapply the tape over the buttons.
  5. BLU Life XL Headphone Port Replacement, Motherboard: 手順 5、 2の画像 1 BLU Life XL Headphone Port Replacement, Motherboard: 手順 5、 2の画像 2
    • Remove the two 12x3mm screws using the Phillips #000 screwdriver.
    • Remove the ribbon cables.
  6. BLU Life XL Headphone Port Replacement: 手順 6、 3の画像 1 BLU Life XL Headphone Port Replacement: 手順 6、 3の画像 2 BLU Life XL Headphone Port Replacement: 手順 6、 3の画像 3
    • The ribbon cables are attached by zero insertion force (ZIF) connectors. To disconnect the cable, flip up the small locking flap and pull the cable out.
  7. BLU Life XL Headphone Port Replacement: 手順 7、 3の画像 1 BLU Life XL Headphone Port Replacement: 手順 7、 3の画像 2 BLU Life XL Headphone Port Replacement: 手順 7、 3の画像 3
    この手順で使用する道具:
    • Remove the white ZIF connector then remove the cable connecting the digitizer to the motherboard by gently pulling.
    • An adhesive pad attaches this component to the motherboard. To remove it, use a pair of tweezers to gently pry it upwards.
  8. BLU Life XL Headphone Port Replacement: 手順 8、 3の画像 1 BLU Life XL Headphone Port Replacement: 手順 8、 3の画像 2 BLU Life XL Headphone Port Replacement: 手順 8、 3の画像 3
    • The motherboard should now be free from its mount in the phone, but it is still connected to the PBC data cable. To remove the cable from the motherboard, gently pry upward.
    • The motherboard is now free and can be replaced.
  9. BLU Life XL Headphone Port Replacement, Headphone Port: 手順 9、 2の画像 1 BLU Life XL Headphone Port Replacement, Headphone Port: 手順 9、 2の画像 2
    • There are 5 soldering points holding the headphone jack to the motherboard. Desolder the 5 solder points and remove the jack.
    • For help with soldering and desoldering, check out this guide.
終わりに
作成者
2人の作成者と共同で作成されました。
Matthew Hook
メンバー登録日: 03/25/19
439 ポイント
4のガイドは作成済み
チーム
IUPUI, Team S1-G6, Hovde Fall 2019 IUPUI, Team S1-G6, Hovde Fall 2019人のメンバー
IUPUI-HOVDE-F19S1G6
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 156
