メインコンテンツにスキップ
Asus VivoBook X202E-DB21T Motherboard Replacement
John Thomas
John Thomas とその他 2 人の作成者
最終更新日: April 11, 2019
15分
難しい
The motherboard is the brain of the computer. It controls everything from image generation to file access and everything in-between. This component can get damaged due to liquid exposure, drops from tall heights, and insect infestations. Take care to make sure the motherboard is disconnected from power before starting.
必要な工具と部品
ツール
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
  1. Asus VivoBook X202E-DB21T Motherboard Replacement, Battery: 手順 1、 2の画像 1 Asus VivoBook X202E-DB21T Motherboard Replacement, Battery: 手順 1、 2の画像 2
    • Flip the device such that the labels are on top.
    • Use a Phillips #1 screwdriver to remove the four 8mm screws near the back.
    • Use the same screwdriver to remove the four 5mm screws in the front.
    • Use the same screwdriver to remove the single 9mm screw in the center.
    • Make sure that the device is powered down and unplugged.
  2. Asus VivoBook X202E-DB21T Motherboard Replacement: 手順 2、 2の画像 1 Asus VivoBook X202E-DB21T Motherboard Replacement: 手順 2、 2の画像 2
    • Remove the back cover by gently prying with a spudger.
  3. Asus VivoBook X202E-DB21T Motherboard Replacement: 手順 3、 2の画像 1 Asus VivoBook X202E-DB21T Motherboard Replacement: 手順 3、 2の画像 2
    • Remove the eight 5mm screws using a Phillips #1 screwdriver.
    • Do not puncture the battery.
  4. Asus VivoBook X202E-DB21T Motherboard Replacement: 手順 4、 1の画像 1
    • Disconnect the battery ribbon cable from the motherboard.
  5. Asus VivoBook X202E-DB21T Motherboard Replacement: 手順 5、 1の画像 1
    • Remove the battery from the laptop.
  6. Asus VivoBook X202E-DB21T Motherboard Replacement, Hard Drive: 手順 6、 2の画像 1 Asus VivoBook X202E-DB21T Motherboard Replacement, Hard Drive: 手順 6、 2の画像 2
    • Unscrew the three 4mm screws holding the hard drive to the board.
  7. Asus VivoBook X202E-DB21T Motherboard Replacement: 手順 7、 2の画像 1 Asus VivoBook X202E-DB21T Motherboard Replacement: 手順 7、 2の画像 2
    • Pull on the tab on the left side of the hard drive and slowly disconnect it from the board.
  8. Asus VivoBook X202E-DB21T Motherboard Replacement, CMOS Battery: 手順 8、 2の画像 1 Asus VivoBook X202E-DB21T Motherboard Replacement, CMOS Battery: 手順 8、 2の画像 2
    • Unplug and remove the CMOS battery.
  9. Asus VivoBook X202E-DB21T Motherboard Replacement, Motherboard: 手順 9、 2の画像 1 Asus VivoBook X202E-DB21T Motherboard Replacement, Motherboard: 手順 9、 2の画像 2
    • Unscrew the five 5mm screws holding the left board together.
  10. Asus VivoBook X202E-DB21T Motherboard Replacement: 手順 10、 2の画像 1 Asus VivoBook X202E-DB21T Motherboard Replacement: 手順 10、 2の画像 2
    • Unplug the two connectors on the left board.
  11. Asus VivoBook X202E-DB21T Motherboard Replacement: 手順 11、 3の画像 1 Asus VivoBook X202E-DB21T Motherboard Replacement: 手順 11、 3の画像 2 Asus VivoBook X202E-DB21T Motherboard Replacement: 手順 11、 3の画像 3
    • Remove the single 3mm screw from the sound chip.
    • Unplug the sound chip.
    • Remove the sound chip.
  12. Asus VivoBook X202E-DB21T Motherboard Replacement: 手順 12、 1の画像 1
    • Remove the six 4mm screws holding the fan and CPU cover.
  13. Asus VivoBook X202E-DB21T Motherboard Replacement: 手順 13、 2の画像 1 Asus VivoBook X202E-DB21T Motherboard Replacement: 手順 13、 2の画像 2
    • Unplug the fan.
    • Remove the fan and CPU cover.
  14. Asus VivoBook X202E-DB21T Motherboard Replacement: 手順 14、 1の画像 1
    • Unscrew the nine 4mm screws holding the right board together.
  15. Asus VivoBook X202E-DB21T Motherboard Replacement: 手順 15、 1の画像 1
    • Remove the two remaining connectors on the board.
  16. Asus VivoBook X202E-DB21T Motherboard Replacement: 手順 16、 1の画像 1
    • Remove the right board.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
John Thomas
メンバー登録日: 01/13/19
756 ポイント
6のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 7
今までの合計 1,563
