メインコンテンツにスキップ
Asus ROG G751JL-BSI7T28 Fan Replacement
Kristen Gismondi
Kristen Gismondi とその他 5 人の作成者
最終更新日: December 28, 2020
15 - 35 分
中レベル
This guide will demonstrate how to replace the fan in the Asus ROG G751JL-BSI7T28 laptop. The fan of a computer is critical to keeping the device cool, making its performance and longevity better. Symptoms of a faulty fan can include frequent overheating during heavy or normal computer use.
This guide is compatible with the following ASUS models: G751, G751J, G751JM, G751JT, G751JL, and G751JY.
Before beginning, make sure to power off your device before starting this guide to prevent any electrical injuries or damage to your computer.
必要な工具と部品
ツール
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
  • Phillips #0 Screwdriver
もっと見る
  1. Asus ROG G751JL-BSI7T28 Fan Replacement, Back Panel: 手順 1、 1の画像 1
    • With the laptop closed, turn it upside-down so the bottom is facing up toward you.
  2. Asus ROG G751JL-BSI7T28 Fan Replacement: 手順 2、 3の画像 1 Asus ROG G751JL-BSI7T28 Fan Replacement: 手順 2、 3の画像 2 Asus ROG G751JL-BSI7T28 Fan Replacement: 手順 2、 3の画像 3
    • Place a spudger into the notch, and pry the small triangular piece away from the laptop.
    • Using a Phillips #00 screwdriver, remove the single 3 mm screw.
    • Place a spudger beneath the back panel and pry it away from the laptop.
  3. Asus ROG G751JL-BSI7T28 Fan Replacement, Display Assembly: 手順 3、 2の画像 1 Asus ROG G751JL-BSI7T28 Fan Replacement, Display Assembly: 手順 3、 2の画像 2
    • Remove all 5mm Phillips #00 screws from the back cover.
  4. Asus ROG G751JL-BSI7T28 Fan Replacement: 手順 4、 2の画像 1 Asus ROG G751JL-BSI7T28 Fan Replacement: 手順 4、 2の画像 2
    • Use a spudger to pry the disc drive out of the laptop.
  5. Asus ROG G751JL-BSI7T28 Fan Replacement: 手順 5、 3の画像 1 Asus ROG G751JL-BSI7T28 Fan Replacement: 手順 5、 3の画像 2 Asus ROG G751JL-BSI7T28 Fan Replacement: 手順 5、 3の画像 3
    • Open the laptop and turn it so that the ASUS logo is facing you.
    • Gently lift up the display hinge housing shroud, but don’t pull it completely away yet.
    • Disconnect the RGB light power cable in the shroud, now the shroud can be put aside.
  6. Asus ROG G751JL-BSI7T28 Fan Replacement: 手順 6、 3の画像 1 Asus ROG G751JL-BSI7T28 Fan Replacement: 手順 6、 3の画像 2 Asus ROG G751JL-BSI7T28 Fan Replacement: 手順 6、 3の画像 3
    • Remove the 5mm Phillips #00 screws.
    • Lift up the silver hinge brackets on each side of the laptop.
  7. Asus ROG G751JL-BSI7T28 Fan Replacement: 手順 7、 2の画像 1 Asus ROG G751JL-BSI7T28 Fan Replacement: 手順 7、 2の画像 2
    • Remove the 5mm Phillips #00 screws from the hinges.
    • Detach the ribbon cable and remove the display assembly from the laptop.
  8. Asus ROG G751JL-BSI7T28 Fan Replacement, Keyboard Assembly: 手順 8、 2の画像 1 Asus ROG G751JL-BSI7T28 Fan Replacement, Keyboard Assembly: 手順 8、 2の画像 2
    • Carefully lift the keyboard up, being careful to not damage the fragile ribbon connectors.
    • Use an opening tool to detach the ribbon cables connecting the keyboard to the rest of the laptop.
    • Remove the keyboard from the laptop.
  9. Asus ROG G751JL-BSI7T28 Fan Replacement, Fan: 手順 9、 2の画像 1 Asus ROG G751JL-BSI7T28 Fan Replacement, Fan: 手順 9、 2の画像 2
    • Remove the fan's power cable by pulling carefully outward towards the fan.
  10. Asus ROG G751JL-BSI7T28 Fan Replacement: 手順 10、 3の画像 1 Asus ROG G751JL-BSI7T28 Fan Replacement: 手順 10、 3の画像 2 Asus ROG G751JL-BSI7T28 Fan Replacement: 手順 10、 3の画像 3
    • Remove the 5mm Phillips #00 screw.
    • Pull up on the black tab connected to the fan. This will pull it away from the cooling fins, allowing it to be removed.
    • Remove the fan from the laptop.
終わりに
作成者
5人の作成者と共同で作成されました。
Kristen Gismondi
メンバー登録日: 11/12/14
92,132 ポイント
241のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,465のガイドは作成済み
コメント 1 件
What's the fan model?
Andres Landazuri - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 823
