メインコンテンツにスキップ
2013 Honda Civic Brake Light Replacement
Abdullahi Mohamed
Abdullahi Mohamed とその他 人の作成者
最終更新日: January 14, 2023
10分
簡単
This guide will show you how to replace the brake light in a 2013 Honda Civic. This guide is only applicable to all the 9th generation Honda Civics between the years 2012-2015. Driving with a burned-out brake light can cause a vehicle to be rear-ended, leading to an accident if it is not replaced. This guide will provide steps on how to replace a burned-out light bulb. Ensure that the vehicle is shut off before engaging in the replacement.
Before beginning this repair, turn off the car, engage the parking brake, and disconnect the battery.
  1. 2013 Honda Civic Brake Light Replacement, Brake Light: 手順 1、 2の画像 1 2013 Honda Civic Brake Light Replacement, Brake Light: 手順 1、 2の画像 2
    • Ensure that the vehicle is shut off before engaging in the replacement.
    • Open the trunk by pulling the latch located on the floor of the driver’s side.
  2. 2013 Honda Civic Brake Light Replacement: 手順 2、 3の画像 1 2013 Honda Civic Brake Light Replacement: 手順 2、 3の画像 2 2013 Honda Civic Brake Light Replacement: 手順 2、 3の画像 3
    • The carpet liner attached to the trunk has a total of six rivet fasteners. There are three rivet fasteners located on the edges of both the right and the left sides of the trunk.
    • Using a flathead screwdriver, remove all the rivet fasteners attached to the carpet liner.
  3. 2013 Honda Civic Brake Light Replacement: 手順 3、 2の画像 1 2013 Honda Civic Brake Light Replacement: 手順 3、 2の画像 2
    • Pull back the carpet liner from the walls of the trunk.
    • Locate the housing compartment for the brake light socket.
  4. 2013 Honda Civic Brake Light Replacement: 手順 4、 2の画像 1 2013 Honda Civic Brake Light Replacement: 手順 4、 2の画像 2
    • Remove the brake light socket from the housing compartment by turning it ¼ of a turn counterclockwise to unlock.
    • Pull the brake light socket from the housing compartment.
  5. 2013 Honda Civic Brake Light Replacement: 手順 5、 3の画像 1 2013 Honda Civic Brake Light Replacement: 手順 5、 3の画像 2 2013 Honda Civic Brake Light Replacement: 手順 5、 3の画像 3
    • Remove the burned-out light bulb from the brake light socket.
  6. 2013 Honda Civic Brake Light Replacement: 手順 6、 2の画像 1 2013 Honda Civic Brake Light Replacement: 手順 6、 2の画像 2
    • Insert the new brake light bulb into the brake light socket.
  7. 2013 Honda Civic Brake Light Replacement: 手順 7、 2の画像 1 2013 Honda Civic Brake Light Replacement: 手順 7、 2の画像 2
    • Insert the brake light socket back into the housing compartment by turning it ¼ of a turn clockwise to lock.
    Excellent guide!
    This video is a clear instruction as well for those who like video:
    https://youtu.be/IWiAWUPTdhM
    Dylan Nemes - 返信
    Clear instructions. 👍🏽
    With photos! 👍🏽👍🏽
    MaxB - 返信
ゴール
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Abdullahi Mohamed
メンバー登録日: 09/13/21
226 ポイント
1ガイドが承認済み
チーム
York University, Team 2-7, O'Regan Fall 2021 York University, Team 2-7, O'Regan Fall 2021人のメンバー
YORK-O'REGAN-F21S2G7
1 メンバー
2のガイドは作成済み
コメント 1 件
Tebrikler,çok güzeldi.Bagaj teli koptuğunda ve arka camlar açılmadığında ne yapmalı? Bunlarıda açıklarsanız sevinirim. Kolay gelsin..
Adnan Dondurmaci - 返信
コメントを追加
統計データ:
過去 24時間: 17
過去 7 日: 84
過去 30 日: 361
今までの合計 10,636
