フィリップスSonicare FlexCare シャフトの交換
必要な工具と部品
パーツ
ツール
もっと見る
このデバイスを再組み立てするには、インストラクションを逆の順番に従って作業を進めてください。
50 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
38 件のコメント
Where do you get a replacement shaft? I can't find any online
You don't need to pry the bottom plate off and risk damaging the seal. Simply apply firm pressure on the shaft against a table while simultaneously wiggling the bottom plate back and forth with a large flathead screwdriver inserted into the charging hole on the bottom. It will pop off smoothly leaving the seal untouched and not scratching the housing or charging plug.
Like the previous comments I also am looking for the replacement shaft. If anyone has found a source please leave a comment with regards to where they can be found.
Thanks for the help
