メインコンテンツにスキップ
The Motorola DROID 3 is a smartphone by Verizon Wireless running the Android 2.3 operating system by Google.
9回答 すべてを表示
Droid 3 Keyboard replacement
I have a Droid 3 that has a keyboard that is starting to get unresponsive keys when pressed with an average amount of pressure. It requires a good mashing for the space bar, Z, M, @ keys.
This question was posted before, but no reply. ( it has been posted twice )
I couldnt find manual somewere, people refered me to this website, i hope i can get the help i need here.
Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
ベストアンサー
Hi. Unfortunately it seems we do not have any repair guides for the Motorola Droid 3 at the moment. But we do have a Motorola Droid 3 Teardown. Be advised though, Teardowns provide a look inside a device and should not be used as disassembly instructions. If your goal is to replace the keyboard, you may follow the teardown at your own risk. Good luck.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
well yeah, thanks for your answer first. I have seen the teardown, but i am not sure. If it is not neccessairy, to completely pull everything out, i will be busy for a long time, for nothing, with a chance to brick it ( i am not so experienced with it )
With previous model, it does not need to
http://www.youtube.com/watch?v=NAgGtK4K4...
さんによる
コメントを追加
I would like some help with this too. Certain keys are becoming unresponsive.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
what have you tried, which keys are not responding? Give us more details and remember that you posted your question as an answer to an old question. Once we have more information, this may be converted to its own question. That way more people will see it and you may get the answer you will need to fix your phone. :-)
さんによる
コメントを追加
回答を追加する
Ozi さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 1,971
