メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2009年中期モデル A1278 / 2.26GHzまたは2.53GHz Core 2 Duoプロセッサ EMC 2326
MacBook Pro screen fading out
Hi there!
I found some similar questions, but none specific enough to make sure they were the same problem, and none with detailed solutions.
A video of the symptoms before I explain with words:
My Macbook's screen sometimes starts fading out. First the pixels get wider, meaning the image seems pixelated. Then the colors start changing, until it gets inverted, then it fades to completely dark grey.
There's no correlation of when it does that and when it doesn't. Sometimes I am just working while everything is normal, and all of a sudden it starts. Sometimes it’s in the morning, I am just waking it from sleep, without even touching the screen, and it’s in that state.
If I then try to bend a little bit the upper left corner of the screen, it goes back to normal. Sometimes it’s enough to keep it working without my pressure. Sometimes as soon as I let go, it starts fading again, and I have to push the whole computer against something to exert that pressure while I work.
Sometimes the problem will remain for weeks and months, and at some point go away for weeks and months.
Sometimes I have to press very hard for the screen to come back to normal, sometimes a very gentle touch will suffice.
It’s mostly on the upper left corner that I have to bend. Sometimes it’s on the upper right corner, but rarely.
What I tried
When I plug an external display, it works fine.
I tried opening up the Macbook and disconnecting the screen, vacuuming the cable, socket, and everything.
Sometimes after I put everything back together, the problem goes away for a few weeks. Sometimes it doesn’t change anything.
I also tried opening the case while the laptop is on, and moving a little bit the display cable, to see if it changes anything. It didn’t.
Other things I noticed
I noticed that some kind of shield on the motherboard’s socket is out of position. But it seems unlikely to me to cause the problem:
画像
I also noticed a visual irregularity on the display cable’s outer wrapping, but I don’t know whether that’s damage or not:
画像
画像
I very recently noticed that the top part of my LCD is unglued from its shell. But I don’t know whether it was there before, and thus could be a cause, or whether it’s the consequence of my bending the top left corner of the screen so many times.
How I see things
It seems to me the screen itself is fine.
So I feel like it could be either the socket on the motherboard, or the cable, or the socket on the LCD. Right?
Questions
Does anyone know whether there is a quick fix to this, or how to narrow down the cause?
My partner’s laptop is a 2010 macbook pro, so the same but one year younger. Do you know if I could plug her screen onto my laptop? If so I could rule out the motherboard socket, or conversely incriminate it.
Thanks a lot in advance for the help!
Update after swapping screen
So I tried swapping screen with my partner's laptop.
One important note, is that BEFORE doing so, I couldn't manage to get my screen to fail completely. For some reason it was working fine. I had to bend it a little bit for it to start pixelating and fading out. Basically the opposite of when it's failing. When it's failing, I have to bend it to get it back to normal.
This time it was working, and I had to bend it slightly to get it to fade away.
After swapping it with my partner's screen, here were the results.
On her laptop, with my screen, behaviour was the same: screen was working, but if I bent it slightly, it would exhibit the same symptoms, first pixelating then fading out.
On my laptop, with her screen, it was working flawlessly. I tried to bend it, to change angle etc, it would always keep showing the image perfectly.
After swapping the screens back to their respective owners, the behaviours are back to what they were. My partner's laptop is working flawlessly, and mine is in the same situation: it's working right now, but if I bend the screen slightly, the symptoms show up.
I don't want to make conclusions myself, because I am not an expert, but it seems to me to hint that my motherboard is fine, and the problem lies either in the cable or the LCD's connector or the LCD itself.
What do you think?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント:
It would be kinda pointless to swap the display from your partnerss laptop, instead just swap over the HDD or SSD. @Danj is this the same issue I had with my 2015 model? What happened here with the screen? It has the same effect!
さんによる
@livfe - Your issue was a bad T-CON. Here we have a bad logic board connector as it's become damaged. Here the fade-out is the lost of video signal as the T-CON is being starved of the updated screen refresh so the currently drawn screen fades.
The connector interface is not stable! This is similar to a ceiling light bulb getting loose so it flickers as people walk on the floor above or after turning off it magically shuts off as the bulb heats up changing the connection, so you let the bulb cool down and it works to fail once again!
Here the connection is breaking down between the cable and the logic board.
The proof is the stability of the external display image.
さんによる
コメントを追加
2件の回答
@johndupont yep. It's either the cable not properly locking in place, shortening out and or losing contact with the display connector. Hopefully it's the display cable, since otherwise you will have to replace the display connector on your logic board. The LCD is the same from the late 2008, late 2009 to the mid 2010. So if that is what your partner's computer is, then yes, you can use that to check. Let us know what you find out. MacBook Pro 13インチ Unibody Mid 2009のディスプレイの交換 MacBook Pro 13" Unibody Mid 2009 LCDの交換
MacBook Pro 13" Unibody Mid 2009 ディスプレイの画像
ガイド
難易度:
中レベル
1 - 2 hours
MacBook Pro 13" Unibody Mid 2009 LCDの画像
ガイド
難易度:
とても難しい
1 - 2 hours
このアンサーは役に立ちましたか?
スコア 0
11 件のコメント:
Thank you VERY MUCH for the very swift and helpful reply.
I'll try swapping my partner's screen then.
If it's the cable, could it be that it's unseated from its connector on the LCD side? If then I could just try reseating it?
Again, a very big thank you for your help!
さんによる
@johndupont If it would be unseated it would not be an intermittent error. It would do this all of the time. Your LCd is losing signal either directly at the connector or at the damaged cable end. Once you test it with your other LCD (hopefully that one has an undamaged cable) and it works okay then you know it is your cable. If the currently working one also displays the same error then you know it is the logic board connector. Replacing the connector should repair this. Of course, that will require some board level repair soldering but it definitely can be done. Just out of curiosity, would you know what may have happened to this board and how the connector might have gotten damaged?
さんによる
Thanks a huge lot again for the swift and helpful reply.
To answer your question, the problem started out of nothing. In particular, I had not disconnected the screen or the display cable ever.
By the way, DanJ seems to be certain that the logic board's connector is faulty, while you are not. Is it because you haven't noticed its picture in my question, or do you have a different opinion?
Thanks again a lot for the help!
さんによる
@johndupont I am for figuring it out first. Sure, could be the connector. Like I said in my original answer, the cable probably does not lock into place properly. Surely the connector needs to be fixed but there may be more to it. It would be easy for me to say it's one thing or the other but I would be making an assumption, which I don't like to do. I prefer you checking it out, since only you can touch, see properly and evaluate it with a hands on experience, that is not possible with remote repair.
さんによる
@oldturkey03 thanks a lot again for your reply!
Yesterday evening I took advantage of a time when screen was completely faded out to open the case with the laptop running, and trying to press on the socket and also pull on the cable. No reaction whatsoever.
I'll try swapping my partner's screen. But she is very reluctant to me doing it. She is very afraid that she'll end up without a laptop anymore.
I might start by opening the screen assembly, and checking the cable, just to see if putting some tape somewhere could fix it.
さんによる
6件以上のコメントを表示
コメントを追加
Sadly the logic board connector is damaged the metal bar which helps compressing the contacts of the cable to the connector has lifted. I've seen this happen a few times when the cable is pulled up vs out before lifting. We also see this issue with the iMac's as well.
Here's one source for the connector LVDS Display Connector (30-pin) you may want to inspect the display cable as it could have been damaged as well.
このアンサーは役に立ちましたか?
スコア 0
10 件のコメント:
Just to make sure there is no misunderstanding due to my picture not showing every angle of the motherboard, I wanted to check that you were certain this was a problem with the connector on the motherboard.
I am no expert but it seems to me that the metal part which is out of position was not exerting any pressure. It looks to me more like an electro magnetic interference shield, or something. It seemed to me that the connector itself was pretty solidly grounded to the motherboard.
Also, if this connector is the problem, does it still make sense that bending the upper left corner of the screen temporarily fixes the bad contact?
Again a huge thank you for your help!
さんによる
@johndupont - The picture is clear the logic board connector needs replacing. As to bending the the display altering things the cable routing would alter the stress of the connection which might just be enough to allow the signal to pass to the data starving T-CON board within the display. You may also need the Display cable too as the tang of the connector could be damaged as well. Here again it's easy to damage as people lift up befor the connection is disconnected which is why the logic board side gets the worse of this.
さんによる
Thanks a lot once again for the very swift and helpful reply!
As a quick fix, since you mentioned this is a problem of not enough compression on the contacts, do you think I could stick something on top of the connector, so that the pressure from the outer case could push things tight?
さんによる
@johndupont - I can't answer that as I wouldn't do it. Applying pressure is a tricky direction.
While it can be daunting to replace, it's a lot easier than it looks. The trick is using Solder-wick to remove the solder and adding a bit of paste flux and reheating the pins from one side to the other while carefully lifting the connector pin by pin using a pick making sure the solder is not holding fast. The connectors body ends are done last. The other way is to use a rework hot air station which is quicker. Or if you have a large iron with a connector tip (large broad tip) allowing you to heat up all of the pins at once.
Or, lastly, applying more solder so all of the pins are loaded so you can heat everything at once. I prefer not doing this as you often snag some of the components nearby or leave solder balls and maybe shorted out components that become bridged.
さんによる
@danj thanks a lot once again for the reply, and for your help.
This is really interesting. It's very good to know that it's not as hard.
Yesterday evening I took advantage of a time when screen was completely faded out to open the case with the laptop running, and trying to press on the socket and also pull on the cable. No reaction whatsoever. So it seems that my idea of a hack to exert pressure would have been useful at all anyway.
I'll try swapping my partner's screen first to check whether the issue persists, and if so try replacing the logic board connector.
さんによる
5件以上のコメントを表示
コメントを追加
回答を追加する
John Dupont さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 21
過去 30 日: 44
今までの合計 210
