2015 MBP 15" Logic Board connectors are slightly different why?
Hello all,
I received a donor logic board from my frieds Mid 2015 15" MBP. Both boards are (IG) compatible. After removing the old board, I replaced it with the donor board, and everything fits perfectly. However, there is a small issue with the trackpad connector and the card reader board flex cable connector.
Old board Trackpad connector is small and the Card reader connector is big
Old board Trackpad connector is Big and the Card reader connector is small
Both configuration are identical. i7 | 2.2Ghz | 16GB | Intel irish pro graphic
I'm really confused right now, and I need to figure this out. Hoping for some help.
この質問は役に立ちましたか?
2 件のコメント
@itsmeapple can you give us the 820-xxxx numbers on your boards? Let's see what we got going on here.
oldturkey03 さんによる
@oldturkey03 Hi, 820-00138-A this is the donor board number. my original board has a slightly different number 820-3662-A
Thank you
Itsmeapple さんによる
