メインコンテンツにスキップ
The Galaxy A14 is a low-end slate Android smartphone released by Samsung in January 2023 as a successor to the Samsung Galaxy A13. Identifiable by model number SM-A145 (followed by version/carrier-specific character.
20回答 すべてを表示
How Can it be turned on without the power on button
The power on button is broken. Is there any other way that it can be turned on?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @galvinjaiki
Try the following and check if it works on your model.
You will need a working computer (Windows or Mac) and the phone's power/data cable.
Turn on the computer and then once it has turned on fully etc, connect the phone's power/data cable to it only at this stage.
Then on the phone press and hold the Volume Up and Down buttons (both together) and then plug the power/data cable into the phone.
Hopefully within a few seconds the phone should turn on with a message stating that the firmware upgrade cannot be performed or similar.
When this happens, release both the Volume buttons and then press and hold the Volume Down button.
The phone should restart and start to turn on. When this happens remove the power/data cable from the phone and release the Volume Down button.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Galvin Jaiki さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 6
過去 30 日: 15
今までの合計 33
