How to remove the base to upgrade the RAM?
I cannot find a video that describes how to do it and I think something is stuck in my laptop. I cannot remove the undecover to upgrade the ram,
この質問は役に立ちましたか?
お持ちのデバイス用の修理ガイドとパーツ一覧とアンサーフォーラムにアクセスする。
この質問は役に立ちましたか?
Before opening the laptop read Disabling the built-in battery on p.66 (p.72 of 112 pdf) of the hardware maintenance manual for the laptop.
Then go to p.68 and p.77 (74 & 83 of 112 pdf) respectively, to see how to remove the battery, base cover and memory modules
According to the specifications for the laptop, it supports 32GB max / PC3-12800 1600MHz DDR3L, non-parity dual-channel capable memory modules in two DDR3L SO-DIMM sockets i.e. 2 x 16GB modules.
このアンサーは役に立ちましたか?
I figured it out yesterday, my issue was that the bottom cover would not come out. there was GLUE between the cover and the fan exhaust...
It came out, not nicely but it did. I cleaned the glue.
How to upgrade Lenovo Thinkpad P50 your P50S maybe similar. Let us know.
This one requires removing the keyboard to get to the RAM
and this one does not.
このアンサーは役に立ちましたか?
This is not true
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 33
