メインコンテンツにスキップ
The Aspire 3 A315 is a repairable laptop by Acer.
20回答 すべてを表示
My laptop is not turn on
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
What happens?
さんによる
コメントを追加
1 件の回答
@mauryasagar it is really hard to help you if you do not give us all the information. We really need more background. Let us know what happened and what you have already tried.
For now do this. Start off with the easy things. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
First, you want to check your power supply. Make sure it has the proper voltages. Check to make sure that the connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see.
iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Maurya Sagar さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 7
今までの合計 17
