メインコンテンツにスキップ
Why is my bluetooth range shortened
My laptop's Bluetooth only connects when the Gadgets are very close to the screen, can someone suggest how to fix it??
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @sakshamjha
Do you have the same problem when connecting to WiFi?
If so, since both the WiFi and the BT use the same antennas there may be a problem with the antenna connection (loose?) to the WiFi/BT card.
Here's the hardware maintenance manual for the laptop.
Go to p.58 to view the procedure to remove the WiFi card.
You don't have to remove the card, just check that both the antenna cables are securely connected to it - see image on p.59.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
i have a laptop so i believe there so there is no antennas in my laptop(i am not very clear on this) but still I'll check it out
さんによる
@sakshamjha
You selected a Lenovo V14 G2-ITL laptop as the one that you're asking about so I linked the manual to show you where to check the antennas!
The laptop must have antennas otherwise the signal range would be too short to be able to use the WiFi/BT effectively.
さんによる
コメントを追加
回答を追加する
Saksham Jha さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 9
今までの合計 32
