メインコンテンツにスキップ
My laptop won't charge
Hello
The laptop suddenly stopped charging
Worked fine until the battery died
I tried with another charger and it didn't help
I replaced the charging socket and it didn't help
Would appreciate help
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Hi @elchanan1
You said that you replaced the charging socket but did you notice if there were any components on the board e.g. power mosfets that were visibly damaged i.e. burnt out or heat stressed?
Post some close up images of the motherboard, in your question above as there may be something to be seen. Here's how to do this on ifixit iFixitでの質問に画像を追加する方法
If there's nothing obvious then you may need the schematics to find out what's wrong.
If the motherboard's model number is NM-C771 (printed on the board), I couldn't find a free download online. This is the cheapest one that I found. You may have better luck in finding a free download.
Update (06/13/24)
Hi @elchanan1
Here's the schematic for the NM-C421 motherboard. Perhaps start checking the circuits from the USB ports as seen on p.69 of the schematic. I don't know the laptop so I'm not sure which port is the charge port.
This time I couldn't find a free boardview file (again cheapest one that I found) so that you know where each of the components shown in the schematic are actually located on the motherboard as no doubt a lot of them won't be designated.
このアンサーは役に立ちましたか?
スコア 1
8 件のコメント:
@jayeff
When I look, everything looks fine
And the model of the board is MN-C421
さんによる
@jayeff
The charging socket is Type-C and by checking the sequence everything is connected as it should be
Could it be the faulty Vbus?
I found a boardview file, can you maybe direct me what to check?
さんによる
@elchanan1
See p.59 and check circuit to U5901as this is the USB-C Power delivery controller IC.
Check it's getting 5V-In, (pin10) Vcon_In (pin25) and VCC3_3V3 (pi26) as these are the voltages that make the IC work.
Don't short out the pins with your meter when testing!
さんによる
@jayeff
I checked voltages
PIN10 0.18V
PIN25 4.1V
PIN26 3.3V
さんによる
@elchanan1
You have to search the diagram for 5V_In points and find out why there's no 5V on the lead e.g. see p.125 VCC5M to D12501 is one point
さんによる
3件以上のコメントを表示
コメントを追加
Well Remove the battery then direct connect the laptop to the with the power point and try to on the laptop, And also change your old battery with the new one.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Elchanan Blumenfeld さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 112
