メインコンテンツにスキップ
Announced on 15 October 2023, identified by model number SM-A055M
20回答 すべてを表示
The touch sensor on phone wears out
Frequently I have to press the on/off button to make my touch screen work again.
There are no cracks on my screen, it's 5 months old.
When scrolling, swiping (I think txting is ok, as it hasn't happened while texting)
It works for a while and randomly it decides not to work, or you have to press firmly but that gets frustrating so I press the on/off side button so it goes back to working but having to do this frequently.
Please can you help
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 8
5 件のコメント
Reset does not fix the phone, tried it, and still encountered same problem,
さんによる
@eleseocapellan then it is time to replace the display as advised in the original answer.
さんによる
my A05 is not touching good
さんによる
Feels like it's a A05 issue, I'm experiencing same, I don't know what to do
さんによる
A05 is rubbish, shame on Samsung 😔
Yes phone crashed while making comment 🤔
さんによる
コメントを追加
4件の回答
最も参考になった回答
@wikitoriat67990 try to rule out any 3rd party App that maybe causing this. Go into safe mode
 1. Press and hold the Volume down key.
2. While continuously holding down the Volume key press the Power key briefly to power up the device.
3. The device will power up in Safe mode. You can now stop pressing the Volume down
Now, see if your touchscreen works 100% of the time. If so, it is a bad app that is causing it. You will have to remove those. You can do that in safe mode as well. Check on here how to do this.
If that did not accomplish anything try and see if you can get into the diagnostics for the touchscreen. Dial this sequence *#*#2663#*#* and test your touch
If nothing works, you got 2 options left. One is a factory reset and one is to replace the display assembly since the touchscreen is part of it.
If you are going to do a factory reset make sure that you have backed up all of your files. You will lose the off your phone. That includes pictures/contacts/music/SMS etc. You will also need to have access to the Google account name and password you have used when you setup this phone. If you do not have that, you will not be able to access your phone after a factory reset.
To find out how to do a hard reset use something like this site as well as many others.
To replace the display assembly and since iFixit does not yet have guide for this, use something like this video Replacement screens are readily available. Get the one that has the midframe already mounted to it. It's a lot easier to replace.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
I have the same problem after a week of buying the device ,I factory reset the device and the problem was not solved. I returned it to warranty and the device returned with the same problem.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
A05 is rubbish, shame on Samsung ☹️
Yes phone crashed while making comment 😤
さんによる
コメントを追加
I honestly liked the Samsung A05's and thought they were great, ideal, low-cost phones till it has proved they are a nuisance.
*Jan 2024 purchased an A05 after liking A04's.
*Feb 2024 phones keyboard slowly stopped responding so brought another, this time with a warranty.
*July 2024 Phone just would not work what-so-ever, gave off every indication of being water damaged despite it not being water damaged.???
-Warranty was $50 to get assessed and the very next day I was giving a new replacement for the fault was not mine.
*Sep 2024 my fourth phone wishing this year has black screened me. Still get notifications/calls etc not that II can answer them.
Awesome
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
A05 is rubbish. Shame on Samsung 👹
さんによる
I hope that the person who designed a05 will get fired for creating such a stupid phone
さんによる
This phone frustrated the hell out of me. I regret picking it up for the dealer.
さんによる
I'm facing the same issue on my Samsung A05. I bought it brand new about 5 weeks ago, and it has never been dropped or exposed to water. I'm wondering why the touchscreen on a brand-new phone would malfunction like this. The Samsung A05 is really disappointing 😞
さんによる
no crack on the phone but not responding unless you press the power button even after pressing you cannot do anything on it.
this bad
さんによる
コメントを追加
Man this is so frustrating I can't even enjoy a game on this device
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Haven't they found a solution to this yet? If i am not wrong it seems like a software problem they can work around. So frustrating.
さんによる
コメントを追加
回答を追加する
Wikitoria Tepania さん、ありがとうございました!
統計データ:
過去 24時間: 9
過去 7 日: 63
過去 30 日: 229
今までの合計 2,987
