メインコンテンツにスキップ
Microsoft Corporationが設計したXbox One Sは、2016年8月に発売されました。Xbox One Sは、Xbox Oneを再設計した製品です。
20回答 すべてを表示
Xbox powers up but does not show picture
Starting a week or so ago my Xbox One S no longer appears to work. I can turn it on (the white Xbox button lights up), but it never send a signal to the TV. The fan will also start spinning (it was replaced a few months ago).
Whenever it's first plugged in, or when I a press the button after it sitting for a while, there is a faint beeping or buzzing sound coming from the Xbox. One short sound, then about a second of silence. It'll do that 8 times then have a longer break, and then start the sequence over again. After a while it stops doing it until you press the on button again.
It's pretty quiet but you can hear the beeping/buzzing in this video:
So far I've tried the following but with no luck:
  • Full power reset (turn off for 30 seconds, unplug, etc)
  • Hard reset using the power button
  • Connect to different TV, using a different power cable and a different HDMI cable
  • Booting into low resolution mode
  • Pushing the eject button repeatedly when booting
  • Inserting and ejecting discs while booting
Are there any other things I can try to troubleshoot what the issue is? I'm wondering if it's maybe the hard drive, but how would I be able to tell?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
could be the hard drive has gone bad, that can cause no image
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
f-aa さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 26
今までの合計 368
