メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2020年11月に発売されたPlayStation 5は、グラフィックが大幅に向上し、革新的なDualSenseコントローラーを搭載しています。近未来的な白黒のカラーリングは、これまでのPlayStationのデザインから大きく逸脱したものです。
Ps5 weird shutdown issue... plz help!
A PS5 I'm working on is having a weird issue I haven't seen before. When you power it on it'll run for anywhere from a minute to 10 minutes perfectly, no video issues or anything. The it will blank out with a long beep only heard thru whatever tv it's plugged into, then immediately power off.
Power it back on it'll do a quick repair for not powering off properly then boot back up. Then it will run again for a minute to ten minutes then the same thing...
I've done a tear down and no obvious signs of anything burned out. Any suggestions on what could be going on? Anything to point me in a direction of a chip to replace or anything would be great.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
11 件のコメント:
Is there a way to get it into a diagnostics mode ?
さんによる
It sounds like it could be an issue with the Power Supply not functioning properly. Can I also ask what the reported issues with the system was that required work?
さんによる
@jmehnert I could tear it down and swap the power supply. I do have a 2nd non functional digital ps5 I picked up I could salvage from.
I'm off work Sunday, I'll try swapping power supplies and will update with findings.
It's just so bizarre, during the time the system is actually up I see no issues with video or functionality. Then poof screen blanks and a long tone then power cuts...
As far as reported issue, wasn't clear. I received system in semi disassembled state, extremely clean almost new in condition inside and out.. not even any dust in the fan or heat sinks. No signs of liquid damage and the fan spins up fine. I looked over the board, applied new liquid metal and carefully reassembled.
さんによる
@jmehnert I replaced the power supply with a known good one. Still same problem
さんによる
@rguilmette1977 I'm also going to go off on a limb and guess that the fan is spinning fine and the CPU is antiquely cooled?
さんによる
6件以上のコメントを表示
コメントを追加
2件の回答
I would even guess a short circuit somewhere on the board
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Sounds like it could be a PSU issue (when it shuts off, what game are you playing etc?). It is hard to tell the exact cause, but you can read the UART error codes by using a UART reader if you have a soldering iron to hand? Here is a guide - https://consoletherapy.com/support/how-t...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Rob G さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 9
過去 30 日: 23
今までの合計 802
