メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP Elitebook x360 1030 G3は、2018年に発売された13.3インチの2-in-1ノートパソコンです。モデル名は、ノートパソコンの底面にある「Project Name」で確認できます。
Charger is not charging
I plug in my charger and it's not charging.its not even showing the light to indicate that it's charging.its hp elite book 1030 g4 . So I went to the check the battery driver and uninstall and re installed the driver. Then it started blinking the orange light multiple times. Also it s a new laptop this is probably the third month with it. And i have updated it to the latest version..after the blinking i decide to shut it down then turn it on again.but it's still not charging. What might be the problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
There could be a few possible causes for this. One possible culprit could be a dead battery - either just bad or simply not being charged. To test this, remove the battery (HP Maint. Guide here - https://h10032.www1.hp.com/ctg/Manual/c0...), put the laptop back together (minus battery), then see if it will run on AC power. If so, then a simple battery replacement will resolve this. If it still won't power on, then I would look at the charging cable itself (perhaps try a different one if available, or if you possess the necessary tools you could test it to determine it is functioning correctly), then the motherboard starting with the AC port. I also am wondering if you have reached out to HP support and if so, what they advised. One other possibility comes to mind (assuming the laptop still doesn't power on with battery removed), though since you asserted the OS/etc is up to date I admit this is fairly unlikely - I have seen various laptops (differing manufacturers - Alienware/Dell, HP, etc) actually stop charging the battery if the OS is not up to date - while no one in the various support departments have been able/willing to explain why, the fact remains that laptops seemingly unable to charge suddenly started charging again when the current patches/etc were installed.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Stacy Jou さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 6
過去 30 日: 25
今までの合計 905
