メインコンテンツにスキップ
Device repair and troubleshooting for the Dell Inspiron 15 inch laptop computer with model number 3567.
Dell Inspiron 15-3567 How to get inside
How do open this up ? I'm used to to getting inside desktop machines, not laptops.. But need to replace failing 1TB spinning HDD with SSD i'm gonna order.
Following this article: Dell Inspiron 15-3567 Fan Replacement - iFixit Repair Guide
Do you really need to remove optical drive ? as it looks like the screws in the image are just holding the metal tray itself, not securing the bottom case at all.
In any case i cannot get access to this part,.. I removed the battery, but them i don't know what to do in order to popup the optical drive, (if needed)
Removed the 8 screws from the bottom casing + screw relating to optical drive in the middle., and i'm guess all i need to really to is remove the screws underneath keyboard. but the only snag is optical drive,, can this be left alone?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Looks like I had to remove optical drive, as it would potentially had issues opening up case after keyboard removal.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Hi @tech198
Here's the service manual taken from this support webpage for the laptop.
Go to p.28 to view the procedure to remove/replace the HDD.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks... Took me a bit to while to disconnect keyboard ribbon connected to board, till i realized they put the orientation of the locking mechanism in reverse. It flips up in the opposite direction, not how you think it does
i.e the hinges of the lock are facing away from the ribbon, yet the lock flips in "from" the ribbon end
さんによる
コメントを追加
回答を追加する
na na さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 113
