メインコンテンツにスキップ
Released in 2010; identified by model P05G. This laptop features a 13" display, solid state drive, and integrated Intel HD graphics.
4回答 すべてを表示
Possible to replace the stock fan with another fan?
I want to know if it's possible to replace the stock fan with something like a Noctua fan
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @wforwipeout
What is the model number of the Noctura fan?
You may be able to replace it if it as the same specifications as the original i.e. dimensions, accommodates the heat sink pipe that is attached to it, has the same voltage/current rating (5V/0.5A) and the same specifications for the speed and temp sensors built into the fan. The airflow rating (3CFM) may not be that important as long as it is not less as this would mean that the fan might have to work harder than it should
If the specifications aren't the same then you may run into cooling problems as the motherboard's fan motor, speed and temperature control circuits were all designed using the above specifications.
Here's the service manual for the model. Go to p.20 (of 44) to view the procedure to remove/replace the fan, to see what it looks like
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
wforwipeout さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 7
今までの合計 67
