メインコンテンツにスキップ
Why is my laptop not charging
When I plug in my the windows battery sign indicates that the laptop is plugged. The laptop itself doesn't charge, the charging brick led lights blue which means it is charging but I do have to say that the brick itself the tip is "slightly" damaged. So what should I do to fix the problem without just buying a new brick.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi @mokachockachino
Connect a voltmeter between the inner and the outer connections on the barrel connector plug on the output cable of the charger and check if it shows 19.5V DC.
If it does flex the cable where it leaves the charger case and also where it enters the cable plug and make sure that it remains steady.
If it doesn't it could be a damaged plug connection or fractured cable.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Moka Chockachino さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 13
今までの合計 94
