Why my phone restart automatically
My phone switch off and on itself
@nitingarg95976 you didn't tell us what you have checked and what you have tried. A bad battery can cause frequent reboots. Start by replacing your battery. Use something like this video to do that.
Of course this assumes that you did the usual software/firmware solutions, like a hard reset (save all your files because they will get deleted), starting in safe mode, updating your firmware, clearing your cache and making sure there are no rogue apps running it the background.
このアンサーは役に立ちましたか?
what could be the reason if the phone is stuck on boot or logo for a long time and needs for both the volume and power button to be pressed simultaneously for a long time.
This is a frequent issue and would like to know a permanent or long term solution.
If your phone restart automatically and frequently there is battery issue. The battery of Vivo s1 and s1 pro is repairable. Just remove the fuse and jump it with soldering. It wil help 1000%
このアンサーは役に立ちましたか?
@rishisaini your answer needs a bit more of an explanation. Why would you remove a fuse (Which fuse?) and apply a jumper to replace the battery?
The whole process is explained in this video
All time my phone restart
このアンサーは役に立ちましたか?
@shaikhshab did you at least try what I suggest in my original answer? Have you changed the battery yet? What have you tried?
過去 24時間: 4
過去 7 日: 15
過去 30 日: 103
今までの合計 3,322
4 件のコメント
Blank screen doesn't start
Jag さんによる
@jag72387 not enough information to help you with that. Be more descriptive.
oldturkey03 さんによる
Battery problem
Subasis Behera さんによる
Restart mobile bar bar
=== Update (05/05/25) ===
Abhishek さんによる
