メインコンテンツにスキップ
Dellが2018年に製造したアルミニウムとカーボンファイバー製のハイエンドノートPC。
10回答 すべてを表示
Stripped Phillip’s #00 screws while trying to replace battery.
Unable to open case to replace battery. Suggestion to remove stripped screws
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
I've used the rubber band trick before, similar to what this guy is doing in the YouTube Video. You don't necessarily need to use a drill like he did, you can also just use a regular screwdriver.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Unfortunately, using the rubber band with a regular screwdriver and also a drill, did not dislodge the screws. One thing to keep in mind is the pressure applied during the process. Not knowing what electronic parts lie under the screws, one has to be careful putting too much pressure on a very thin laptop. Incidentally, those two screws are three times longer than the other twelve screws that secure the frame. My solution was the use of a Dremel tool (with a fine point) and try to drill a straight line channel that will accommodate a regular screw driver. Problem solved.
さんによる
コメントを追加
回答を追加する
Phil Mills さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 177
