Why is my pc not charging?
My pc is not charging even though the charger and the battery are in good condition, the pin is also good.
この質問は役に立ちましたか?
お持ちのデバイス用の修理ガイドとパーツ一覧とアンサーフォーラムにアクセスする。
この質問は役に立ちましたか?
Here are a few suggestions to help troubleshoot the problem:
-Test without the battery: Remove the battery from your PC and try running it solely on AC power. If your PC functions properly without the battery but doesn't charge when the battery is inserted, it could indicate a problem with the battery itself.
-Reset the battery: Some laptops have a built-in battery reset function. Check your laptop's manual or manufacturer's website for instructions on how to perform a battery reset. This can help recalibrate the battery and resolve charging issues.
このアンサーは役に立ちましたか?
過去 24時間: 4
過去 7 日: 11
過去 30 日: 19
今までの合計 520
6 件のコメント
Is this the AC adapter that came with the laptop?
Hast さんによる
@abubekerali how do you know that "the charger and the battery are in good condition" and what pin is also good? How did you check this?
oldturkey03 さんによる
@duhast500 yes it is
Abubeker Ali さんによる
@oldturkey03 I took it a repairing shop 4 months ago, it is the same problem happening now. I tried the charger on another pc it fine and the battery was working until it runs low on charge. By pin I mean the socket that takes in the charger.
Abubeker Ali さんによる
@abubekerali my concern with this is that if this is still the original battery, it is 5 years old and may just have problems holding a charge. Unless of course you have changed it.
oldturkey03 さんによる
1以上のコメントを表示
