メインコンテンツにスキップ
iFixit uses cookies to enhance site functionality, analyze traffic, and personalize ads. By using our site, you agree to our cookie use and Privacy Policy.
Dell XPS 15 7590 Laptop with OLED or touch panel.
1回答 すべてを表示
Laptop won't wake/power on without power adapter connected.
I got a new battery from iFixit matching the model number of the stock battery installed in my laptop (6GTPY, 97Wh), installed it, and calibrated it. I then noticed that within 2 days the health dropped by >10%, and sometimes the laptop wouldn't be able to wake from sleep without the power cord connected. After turning it on I could see that the battery had plenty of charge. I contacted support and they sent a new battery but this one has the same issue with turning on the laptop. Since this has happened twice now I am unsure if it's a faulty battery and was wondering if there was anything I could do to fix this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント:
what are your current battery power settings on the computer?
さんによる
I've basically disabled sleep as this issue seemed to occur more often with sleep. So I have all relevant settings for sleep set to never and use hibernate instead. Even for hibernate I have it hibernate after 10 minutes. The Modern Standby causing excess battery drain was also a factor and I switched over to hibernate before getting the new battery to avoid modern standby.
さんによる
コメントを追加
1 件の回答
Hi @johnsalt
If you haven't already done so, try reinstalling the battery drivers.
Press Windows key + R to open a Run command box.
Type devmgmt.msc and press Enter.
In Device Manager, click on the Batteries categories to expand the list.
Right click on Microsoft ACPI-Complaint Control Method Battery.
Click on Uninstall.
Restart the laptop and check.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
John Salt さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 185
