メインコンテンツにスキップ
2012年10月23日に発売されました。Core i5もしくはCore i7プロセッサ、Apple Fusion Driveを搭載しています。
Hard drive caddy bodged
I'm new to the world of Mac's but I recently bought a cheap mac mini 2012 and updated the RAM and SSD for my daughter. I was so impressed with how cheap it all was (I even sourced a cinema display for it) that I decided to get one for myself.
All was great until I removed the caddy for the HDD and discovered that it didn't have the slots for the screws to mount the second drive. All the rest checks out as a late 2012 except for the drive caddy. I put the drive in and used some tape to keep it in place. Everything went back in, although a little tight and it all works fine. I am concerned that it will overheat as there may not be sufficient air flow to cool it.
Would I be better off finding a replacement caddy, although there are not that many out there, or will the bodge suffice?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
Though it isn’t ideal I would not worry about the tape especially if the Mac stays still. Airflow shouldn’t be an issue since it pulls airflow through the bottom.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
That's brilliant! Thank you and it sooths my worry about the house burning down 👍
さんによる
Although it would help if I could spell "soothe"
さんによる
コメントを追加
回答を追加する
joelhistory さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 98
